New gas heater is hooked up properly and while heating all of a sudden a loud horn noise
  • Heating & Co... Master
  • 3,238 Answers
Was it from the burner gas and air burning off together.
Posted on Dec 14, 2016
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Jun 26, 2014 | Kenmore Kitchen Ranges
My stove heater is making a loud popping noise when it cools
if you are vented into a chimney with out a liner this can cause noise to occur because vent gases are slowed down because of vent build ups more heat into exchanger. If you can not change vent lower gas pressure.
Dec 31, 2013 | Cozy Enclosed Front Console Heater 70,000...
My Jandy lite 2 natural gas heater has a loud clicking noise. It fires up and heats my pool nicely. My problem is.... as it is heating there is a loud clicking noise from the gas valve area. It acts a
I would suspect that it is not the valve making the noise. I would bet it is the thermal expansion of the metal that you are hearing. Other than that, I have seen cases where there is a flow control valve, and depending on its operation, when it opens or closes on spring power it will over shoot and make a loud clicking noise as the clutch overshoots. This will usually only be about 2-4 clicks though, and around pool equipment I doubt you would hear much of it. I would bet more on the thermal expansion. Kind of like the clicking noise you will hear after you have parked your car and the engine is cooling down.
Apr 10, 2013 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
make sure pressure switch is good and wires are tight sounds like pressure switch cutting in and out opening and closing gas valve also make sure wires to gas valve are tight
My water heater have countinous loud sound?
There are several different things the sound could be. If it is a popping noise it could be from the sediment inside the water heater as it is heating. It could also be noise(bang) from the water pipes having excessive pressure. If the water heater is gas it could be the noise from the burner when in operation or gas regulator vibration. Need a better description of the noise to be more helpful.
Nov 05, 2009 | American Standard Water Heaters
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
A loud puff sound on ignition
you need to have the gas valve adjusted properly.
May 12, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Very loud knocking noise that can be felt if touching the unit.
If the heater has a heat sink with a brass non-return valve then this could have a fault creating a hammering noise that resonates through the heater.
Mar 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
