I have a Hubmar Nebulizer that will only hold the first intensity setting. when I click it shows more bars fr a sec and then goes back to one. It isn't doing much at the first setting. Can you help?
HOW DO I GET RID OF THE FRENCH E WHEN I TYPE ?
Usually, when you type, there will be a language bar which will show the language that you are currently typing in. If you click on the FR (French), it will show an option to switch to EN (English). To remove French completely, go into the Control Panel and go to Region and Language. In the pop-up dialog, click on the Keyboards and Languages tab, and then click change keyboards. In the dialog box that appears, you will see all the "keyboard languages" that you have installed. Click on the blue icon saying FR, and click Remove.
(Note: You will not be able to remove a keyboard language if it is the default language of the computer, ie. if the computer is configured in French, you will not be able to remove it)
Mar 01, 2011 | Computers & Internet
Netgear router WGR614v9 used to work fine before but now it has started to make me run for the mill lol. Well, router is all setup to work with my broadband connection, everything seem fine, connection...
Sounds like you're gonna need a replacement.
Have you tried a reset? The little recessed button close to the power input. Paper clip or pen tip.. Hold down 10 - 15 secs. This should restore to factory settings.
Other way is a 30-30-30. With power on, press reset for 30 secs, without releasing button, pull the power, continue holding 30 sec, then withOUT releasing, plug in power and continue holding 30 secs.
Release, let it stabalize, power off and on. That's it. Go into config and do setup all over again.
Contact your providor for details on settings.
If that don't work, it's broke !! Possibly download and reinstall firm ware. From support site http://kb.netgear.com/app/
Jan 22, 2011 | NetGear WGR614 Wireless Router
My ipod plays video for a while then it suddenly stops and goes to the menu home page
your iPod touch might just be running low on memory. to fix that, all you need to do is reboot your device.
now, to reboot your device, simply turn it OFF by holding the power button for around 3 to 5 sec until you see this screen:
.. then continue by sliding the red bar on the top.
After your device is completely turned OFF, turn it back ON by holding the power button for (again) around 3 to 5 sec. Wait for it to load completely and then after, you can watch the video you've been dying to watch without any interruption, except for the weak WiFi signal.
For more iPod touch / iPhone tips, click here.
Feb 16, 2010 | Apple iPod touch
My Dell keyboard is typing french symbols,how do I change it back to english
if you have windows XP follow these steps :-right click on Taskbar-Toolsbar-here check the language bar(should apear in your case french) -right click on the Fr(that apear)-settings -here you will see French keyboard-click Add and select EN-english -than OK and your keyboard should type english letters/
Dec 09, 2009 | Dell 0Y3740 Keyboard
Casio fr-2650 plus calculator
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Apr 05, 2009 | Casio FR-2650Plus Calculator
Poor photo copy when printing 4x6 glossy in cassette tray.
Set the Ink Intensity (Windows) The Intensity setting controls the amount of ink placed on the paper. The higher the intensity the darker (more ink) the printed image will be. If the Intensity setting is set too high, the printed page may become too wet and curl or streak. Follow the instructions below to adjust the ink intensity settings.
  1. Access the printing preferences by opening the printer Preferences / Properties.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  2. On the Main tab, select 'Manual' for 'Color Adjustment', and then click 'Set'.
3.Use the slider bar to adjust the 'Intensity'.
Note: Move the slider bar right to darken the image, and move the slider bar left to lighten the image.
Click 'OK' to complete the setup.
I hope it helps!!!
Dec 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Nebulizer portion is accumulating what appears to be saliva
well i have a inhaller tube to and yes it can be straight and it can slope down too. saliva no it's not possible but it could run down your cheek. or you could go and ask where ever you got the nebulizer from
Dec 01, 2008 | RTO Spider Nebulizer
Clock problem
try holding hte clock/set start button in for 3-5 secs, it sounds as if youve accidently turned of the clock display. .. a common issue especially after turning clocks back.. its a built in feature for people with too many clocks in kitchen, they allow you to turn off the display.
Nov 04, 2008 | KitchenAid KERC507 Electric Kitchen Range
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
