Question about Sylvania LC370SS9 LCD TV
I have a Sylvania Model LC370SS9 M and I can't seem to hook it up to my T.V. Some thing about the format not being right or something like that please help.
  • 176 Answers
SOURCE: i to just purchased a sylvaniia LC370SS9 and
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Posted on Jan 05, 2010
SOURCE: don't know the universal remote code.
hi! i have here a couple of codes for your tv! just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465, 1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!!! goodluck!!!!
Posted on Jun 07, 2010
SOURCE: WHAT IS DIRECT TV CODE FOR SYLVANIA LC370SS9
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
SOURCE: IR interference from LCD TV..on comcast dvr
I have the same issue. I've tried every version of Comcast box there is available. Nothing. Next I'm trying taping off the Sylvania IR and running the volume through an old receiver I have. That is, of course, that there isn't a solution posted here first. Will report back later.
Posted on Oct 27, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Sylvania LC370SS9
Your unit being stuck in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in standby mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
I do not think the defective power board needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Jan 01, 2011
I have a Sylvania lc370ss9 hdtv. When I turn the power on the set remains black, the power indicator flashes green and the power button will not shut it off.
The set has failed to come from standby to on fully---could be the power board but if it will not power off usually it is elsewhere.
Time to have a qualified shop take a look a get a estimate.
Dec 04, 2012 | Sylvania LC370SS9 LCD TV
Sylvania lc370ss9. tv just quit. no power at all when plugged in.(no sandby.nothing seems dead)checked cord and fuse both good. have done alot of searching. power feeds 2 boards. tuner board(i believe it...
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
Apr 25, 2017 | Sylvania LC370SS9 LCD TV
How do you Wall mount a Sylvania LC370SS9 TV
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
Jun 17, 2011 | Sylvania LC370SS9 LCD TV
Lc370ss9 lcd tv turns off immediately after turned on
It may have shorted or failed power supply circuits, or shorted out the backlight inverter board, you will have to open it up and inspect the inside. It goes into shutdown to protect itself right now from further damage. Look at the power supply and the backlight inverter.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find
Jul 20, 2010 | Sylvania LC370SS9 LCD TV
Don't know the universal remote code. Tv did not come with a remote Sylvania LC370SS9
Apr 29, 2010 | Sylvania LC370SS9 LCD TV
Apr 07, 2010 | Sylvania LC370SS9 LCD TV
TV will not turn on
Is the thing plugged in?
Mar 14, 2010 | Sylvania LC370SS9 LCD TV
IR interference from LCD TV..on comcast dvr ...remote for dvr box will not work if i have the tv on..it a sylvania ......37" LCD HD TV model number LC370SS9
Jan 16, 2010 | Sylvania Televison & Video
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Need RCR450 Code for Sylvania LC370SS9
Here's the manual =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Sylvania TV codes are 1004, 1006, 1008, 1019, 1062, 1068, 1069, 1075, 1076, 1088, 1130, 1132, 1134, 1183, 1189, 1251 listed in back of the manual.
Dec 28, 2008 | RCA RCR450 Remote Control
Sylvania LC370SS9 LCD TV Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
