Question about Dryers
Have a dyson hot cold fan keeps saying h2 and heat wont work any advice tried inplugging works for a few minutes then stops saying h2 again
  • Dryers Master
  • 14,584 Answers
Doesn't that mean that it had reached 'Heat 2'? Have you tried increasing the heat setting?
If you have, contact Dyson Warranty Department. Tell them Fixya sent you.
https://www.dyson.com/support/am04/am05-iron-blue/diagnosis-root-menu/machine-not-heating-am04
Posted on Dec 14, 2016
  • 328 Answers
SOURCE: heater not working
the thermostat may be stuck open.or there may be a problem with the door in the heater box that controls the hot and cold air.........or the linkage from the hot cold switch to the door in the heater box
Posted on Dec 12, 2008
  • 1779 Answers
SOURCE: CHRYSLER TOWN & COUNTRY 2003 HEATER PROBLEM
Have you checked the coolant level? If it's low, it will result in diminished heat, and could be the problem.
Posted on Mar 25, 2009
Sergey2121
  • 46 Answers
SOURCE: COST OF REPLACING A THERMOSTAT ON A 2004 IMPALA
Thermostat itself is like 8 dollars, from Kragen, or Autozone.
Posted on Apr 08, 2009
  • 95 Answers
SOURCE: 2003 chevy s10 - keeps blowing out AC fuse. Will
you have a short somewhere problably bad ground , or interferrance from alternaot overloading the circuit... check all ground securlely...if you cant locate it its not going to be cheap for a mech to locate the issue.. good luc kthough ( also check for loose wire behind the fuse box in car.
Posted on May 19, 2009
  • 70 Answers
SOURCE: I have a 1993 Acura Ledgend.
first check to see that you coolant level is full, check it after the engine has cooled down,so there is no pressure in the system. otherwise you possibly have a head gasket in the early stage of failure
Posted on Nov 30, 2009
Hi. I have a Dyson AM05 fan heater purchased July 2014. Whilst the cold air works brilliantly the hot air doesn't work at all. It shows an error message E8. Any advice?
I suspect that the microprocessor detected an overheat fault and is keeping it in E8 mode to prevent fire. The code needs to be cleared somehow. If it has some buttons on the front then try holding one whilst plugging it in. This may reset it. The reset will be something along those lines. Don't open it because if you can't fix it that way you need to take it back to the shop.
Dec 29, 2014 | Dyson Inc Am05 Hot Cool Fan Heater -...
My dyson hot fan will not give out air under 24 degrees?
Hi Charlie, it's Jack at Dyson.
When you adjust the target temperature of your Dyson Hot fan heater (shown on the LED display on the base), you're setting the target temperature you would like the room heated to. The actual temperature of airflow produced by the fan heater will not vary.
If the heater won't run below 24 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 24 degrees. The heater will only turn itself on if the temperature drops below 24 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
I've attached our Getting started video below which shows how to adjust the temperature, using the remote or the controls on the base.
I hope this makes sense. It sounds as if your machine is working correctly, but if you'd like any further advice from our experts you can reach us at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 01, 2013 | Dyson Hot Heater Fan AM04 - Blue
Dyson hot and cold fan only works in hot mode
Hi there, it's Jack at Dyson.
If the heater won't run below 25 degrees, this is likely to be because the temperature of the room you're in is equal to or warmer than 25 degrees. The heater will only turn itself on if the temperature drops below 25 degrees, and once the room temperature reaches this target once again, the fan will turn itself back to monitoring mode.
Nov 09, 2012 | Dyson AM04 Hot Cool Fan Heater White
Keeps shutting off
You cant clean the HEPA filter.. only the blue washable pre filter.
Sounds like the motor is dead or atleast on its way out.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 28, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a problem with my Rinnai hot water heater giving me intermitant hot and cold. The water gets hot and I get in the shower. A few minutes later the hot water stops and I have to shut of the hot water...
We had the same problem - the hot water would only be hot for 3 -5 minutes and shut off, then we had to turn the water off, wait a few minutes, and do it again. VERY FRUSTRATING.
Solution: The Rinnai serviceman showed me the heat-exchanger blower/fan: It was clogged with dust and moths.
Another clue: Our Rinnai was extremely noisy when the heat came on. After the fan was cleaned and replaced, it is nearly silent.
If you are reasonably mechanically inclined:
TURN THE BREAKER / POWER OFF to the unit.
The blower-fan is located in the lower central area of the unit (at least on our unit). If you draw imaginary north-south, east-west lines through the center of the unit, the fan is in the lower-left quadrant. There is a spring clamp securing the black rubber accordian-like tube to the fan. There are two screws that secure the fan to the unit. there are two plugs that connect to the fan, as well as a third air-flow sensor that should be removed. then you can look at the fan unit, as well as the grill on the underside of the heat-exchanger that should be cleaned.
My thought was to go out and get a simple bug-screen, and place it over the air-input outlet vent going outside, but the repair guy said that although it may sound good, if that screen ever gets clogged, or reduces airflow to the Rinnai, then the unit will work harder, or even shut off, giving the same problem.
May 24, 2010 | Rinnai Webstone The isolator EXP tankless...
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
OVERHEATING COMPRESSOR
you can check its starting components. it could be a bad capacitor or a bad start relay. if the compressor starts from cold, it could start right away but as it heats up, it should be able to start also, since after running for a few hours, the compressor will really get hot, it would stop at defrost cycle and re start again after about 30 mins. since it is still hot, if it has a defective starting components, it can not start and that is the time it would overheat.
in any case that the starting components are all ok, then you have a partially burnt compressor. it would run while cold and can not run when hot because the resistance of the wires changes as it gets hot. with this kind of problem, you need to replace the compressor. as you have said, the fan at the condenser is running. if the fan at the condenser is not running, that is also a cause for the compressor to overheats. i hope i was able to help...
Jul 03, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
On button won't stay on
easy fix, unplug the machine sit in front of it. put your thumb on the on/off button and push down and slip your thumb off of it as fast as you can so it pops real loud. Do this ten times and then plug back in and see if it works. ( this came from talking with Dyson people) Hope it works for you. They said this will reset the machine. also acts as a warning that your filters most likely need cleaned.
May 21, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dryers Logo
222 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
