H0w do i ground the lid lock wire - Washing Machines
2008 CTS trunk won't unlock
Hi Jeff,
I was going to say, check fuse/ jump the load side of relay Good post.
Mar 19, 2017 | Cars & Trucks
WL80T65CW1. Why is it displaying fault 234 and will not cycle?
Replace just the lid lock assembly to start with and see how it goes. Lids are quite expensive and don't usually need replacing. You can always get a lid later if you still have problems.
Aug 25, 2015 | Fisher and Paykel Aquasmart wl80t65c
How can I activate an iPad mini that is iCloud locked
I would go to an Apple Store and ask for help.
kolbrun
Dec 22, 2014 | iPad mini Tablets & eReaders
Locking mechanism
replace the lid lock ! its a safety measure. I would not recommend removing or bypassing lid lock. just replace it. without the lid lock it will work with lid open. good-day ! if you really what to bypass the lid lock. Find the wire that goes to the switch. Splice the wires together and the machine will think the lid is shut all the time. if you can not get top of washer off. just call an appliance center and give them the model and serial number. and they should be able to tell you. good-day !
Dec 13, 2011 | Kenmore Washing Machines
Power decklid won't pull trunk down. Replaced actuator and switch in decklid and the servo in the trunk.. works intermittently
If it works intermittently, you probably have a damaged wire -- my guess would be where the wiring harness goes to the trunk lid. The constant motion of use can damage the wires internally. They still look ok on the outside usually, you'll have to check them electrically (with a meter or test light) The other possibility is damage to the harness that goes to the latch from something moving in the trunk and hitting it. Good luck.
Apr 26, 2010 | 1993 Lincoln Town Car
H0w t0 turn off num loCk 0n PC eee 9000
hi, it is by using the Fn key and pressing num lock. pressing num lock without pressing the Fn shall go to Scroll lock.
try it. should work.
Feb 17, 2010 | ASUS Eee PC 900 PC Notebook
2002 Mercury Grand Marquis. Backup lights won't work
Does pushing the trunk release button make the back up lights illuminate? Has the car been serviced or wrecked before this problem? Have you been golfing and put clubs in the huge trunk. Either the ground wire for the trunk lid devices is bad or the trunk release wire (purple/orange) and the reverse lamps wire (purple/white) have been reversed.
Mar 22, 2009 | 2002 Mercury Grand Marquis
How do you clear a od error code on a maytag fav6800aww
I agree with fastnhonda troubleshooting. I will just toss out some additional info. I’m an owner like you just trying to troubleshoot from a distance. The OD alarm is signaled by the control board when the control board has not seen a lid open signal from the left lid lock for three completed wash cycles. Could be corrosion issues with the left lid lock and or plug connecting to the left lid lock. If you pull the power plug on the machine then re-power up does the “OD” alarm clear? This might clear the “OD” alarm for three wash cycles. If it does can you do this; open the washer lid and start a Spin Only cycle with the lid open do you throw an OP (Lid Is Open) alarm to the console? If so do you clear the “OP” alarm when you close the lid? I’m checking the signaling functionally of the Left Lid Lock assembly of the magnetic reed relay and lid magnet thru the left lid lock and plug back to the control board.
If no results come from above testing and you want to DIY the repair I would remove the left lid lock (remove the left lid lock as shown on page 34 of the SM) and inspect for corrosion issues as the other forum member speaks to and a possible broken wire connection on the magnetic reed relay. See the red & black wire going to magnetic reed relay switch as shown in the pic. below. Note the black wire is broken away from one end of the magnetic reed relay do to corrosion. If you take apart the left lid lock the tabs holding the case halves together break off very easy so be careful on disassembly. I would not replace the right lid lock just yet. Removing the plugs on the lid locks is difficult so be careful. I would remove the left lid lock and inspect and clean up wih WD-40 if there are corrosion issues such as shown below or a broken wire (re-solder) on the magnitic reed relay. If this doesn’t resolve the “OD” alarm I would then replace the left lid lock only at this time. The right lid lock is not needed for normal washer operation.
Support info;
Left Lid Lock always give you pats supplier you machine model number when ordering parts. No machine serial number is required for this part.
The Service Manual for reference. Sears Parts Direct for reference.
Disconnect the washer power cord.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Jul 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
