Question about GE Ovens
I have ge oven error cood - GE Ovens
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
GE oven displays an F 7 error message
Hi Mark, Why not search online for this error code + ge oven? You'll get the info you need but don't necessarily want!
Jul 15, 2015 | GE Ovens
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
I have a GE double wall oven. I have a F7 errot on display. I unplugged the ribbon cable and shortly recieved a F0 error code on both the upper and lower side of the display. I replaced the ERC. it...
The F7 error coode means either the ERC or touch pad is bad. Having already replaced the ERC,replace the touch pad(the part w/the ribbon cable)
Aug 04, 2011 | GE Ovens
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
My GE Oven JTP 14 displays an F9 error and shuts off.
F9 error - Lock switch error.
Resolution - Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Hope i helped you.
Sep 02, 2009 | GE Profile JTP18 Electric Single Oven
F7 error code
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE Profile double Built-In Oven error Code
According to the GE User manual... any F# error code means you have a function error and they suggest you press the CLEAR/OFF pad and allow the oven to cool for one hour. Then put the oven back into operation. If the function code repeats, disconnect all power from th eoven for at least 30 seconds and then reconnect it.. If it still comes back.. call for service.. however it has been my observation that F0 is usually a shorted off key on the keypad. Hope this helps..
Sep 21, 2008 | GE Profile JTP56 Electric Double Oven
Error code f 03 has come up on our oven
I know what you mean. I was cooking with this appliance tonight and suddenly it displayed an f-3 code. My advantium oven is less than 8 months old. Not sure how this happened or how to fix the problem. In order to sleep tonight (the constant beeping) I had to shut power off at the breaker pannel. Is this representative of the the type of quality that GE stands for???? I am sooo frustrated. I cook with my advantium oven all the time and love the dual abilities of this appliance. Like I said this is brand new and to have the f-3 code which apparently (from what I read) is a failed key pad. I am very dissapointed and am begining to think about pulling my stock from this company!
Nov 05, 2007 | Blodgett DFG-100 Gas Single Oven
Ovens Logo
24 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
