Question about Garden
I have a Fisher v blade and when I use it, it keeps shutting off until it is warmed up. I have a new battery and alternator (220 amp)so I don't think it's that.
  • 6982 Answers
SOURCE: good batt & new alternator.. but battery keeps losing charge
Make sure all connections at alternator are attached. On some, the regulator is inside the computer and if bad, requires computer change.
Posted on Jun 26, 2009
co7196
  • 3433 Answers
SOURCE: my silverado 3500 01 battery keeps going
Ck the charge rate at the battery posts. The proper range is 23.6 to 14.2v , The higher the voltage the llower the amps. Ie; at 13v Alternator is about 10% under capacity. @ 12v it is charging at max capacity. @ 15 v isthe alt is not charging but frying your battery. 9amps is ok if battery is fairly charged but at start up it should sit on 13-13.6 volts. for about 15 seconds the start climbing to less charge towards 14.2.
Posted on Oct 15, 2009
SOURCE: Put in new starter, alternator, & battery but drains it & dies.
It does not take much to drain a battery e.g interior light left on over night etc. OK switch everything off, disconnect the negative lead and fit a multimeter between the battery terminal and detached lead. Set scale range to 1amp. It should read near zero. Methodically remove and reinsert the fuses one at a time noting any changes whilst each fuse is removed. By a process of elimination you will find the fuse that it responsible for draining battery current. This fuse corresponds to the electrical circuit within which there is some fault or short. The starter is unlikely to blame since once the car is running the alternator will more than compensate for any current loss. Just a thought the truck is getting on in years so it could be worth also checking some of the mechanical items that might upset the running if not now certainly in the future: Exhaust GAS Recirculation (EGR) valve and inlet, Throttle Position Sensor (TPS) and Idle Air Control (IAC) valve. All are located fairly close to the throttle body and are really easy to overhaul on a preventative maintenance basis. If you don't know what they are look them up on Youtube
Posted on May 02, 2010
  • 38 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
  • 8 Answers
SOURCE: keep asking pass code i
all of the bluetooths have universal codes. it is either 0000 or 1234. easy to find on website which is yours. also your carrier will have it. I looked it up and 0000 is your code.
Posted on Oct 15, 2010
Sluggish ignition start
I think your mistaken. Your battery will lose cranking power as the temp drops. Warm battery may work just fine, untill it gets below freezing temps then the cranking amps are so low its sluggish. Buy a high cranking amp battery and you will be good as gold mate!
Dec 10, 2013 | 2007 BMW X3 3.0si SAV
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
20 amp engine fuse for 2000 plymouth grand yoyager keeps blowing
I don't have a picture, just a diagram. In the power distribution center, I see 20A fuse 3 for the automatic shut down relay and 20A fuse 5 for the fuel pump relay. No 15A fuses in the vicinity
Sep 25, 2012 | Cars & Trucks
New battery keeps going dead no low voltage light
Have the vehicle taken to one of many places that will test the Alternator output etc--narrow it down first without replacing that.
Voltage may drop enough to prevent starting without triggering the low voltage issue.
Jun 14, 2012 | 1997 Ford Escort
Battery drain
A wiring diagram of entire vehicle & the
ability to use a half decent volt meter, on the
amp & millamp scale
Pull all fuses,one at a time, until something
indicated the current drain & it stops
Need the meter in series in either battery cable &
ability to see the meter
You have to know what relays need to time out & see
if they do,so don't keep opening the door or you start
the process over.
The battery has to be good also
Not over 5 years old & has to read over 12.6 V when you start
your checking
If this is a 20 year old car,visually check for corroded
fusible links first & don't forget alternator diode leakage
May 23, 2012 | Cars & Trucks
Battery runs down after setting for 48 hours . Has new battery
Generally when a battery keeps dying even after replacement one of two things is the problem. Either the alternator or alternator belt (however, if this was the case, one would think it would die while driving down the road) OR Something is drawing power that shouldn't be, for example, let's say the switch that shuts off the light in the trunk is broken, so the light is staying on all the time and you may not be aware of it, constantly draining the battery. A quick test for the alternator is to visually inspect the belt, check belt tension. Measure battery voltage using a multimeter, start vehicle, measure battery voltage again, it should be higher than when you measured it with the vehicle off, this is a decent indicator that your alternator is working. To test for a drain on the system, first shut everything off. This includes lights, radio, taking out the keys, closing the doors, turning off headlights, heater, etc. To measure the drain, you must remove the positive battery cable from the battery. Connect a multimeter capable of reading amps DC in series between the positive battery post and the positive battery cable. If you have more than half an amp, you probably have a drain on the battery. Now, with the meter still connected in the manner described, you must remove fuses one by one until you determine which circuit the problem is on (excessive current reading on the meter goes to acceptable levels). This website has a very good description with a few pictures and other information about battery drain:
http://flashoffroad.com/electrical/Batteries/BatteryDrain.html
After determining which fuse the drain is on, you must determine what is now not working (hopefully your fusebox has a diagram on the lid, most do) and troubleshoot that circuit.
Mar 02, 2011 | Jeep Cherokee Cars & Trucks
New battery. abs, battery and service engine lights come on. all headlights and tails flicker and car dies and wont start. jump it let it warm up and doesnt do it for awhile. then at some point it does it...
These are all signs of a bad alternator. The car is running off of only the battery. The alternator charges the battery and keeps the car running. When the alternator quits charging the car will run fine until the battery dies. Then you can jump the battery and charge it, and the car will run fine until all of the electronics and lights run the battery down again.
Jan 25, 2011 | 2000 Pontiac Grand Prix
The battery is not charging properly, have to jump it and then when you try to restart later, it wont start. I talked to an auto person and was told it was the alternater, not sure what to do and dont have...
If the car runs until you turn it off and won't restart, the alternator is charging and the battery will not hold a charge. If it can't hold a charge, it will not be able to restart the car. If the car runs and then dies, the alternator isn't charging. The alternator may be wearing out and not be able to keep the car running and charge the battery. Chances are based upon your description of your problem (sounds like car runs until you shut it off and won't restart), it's a worn battery. If it's 5 or more years old, you probably need a new one. If you are not sure, test them. I think your battery is finished.
Apr 16, 2010 | 1989 Toyota Camry
My Orion 2500D amplifier turns off then back on at high volume
you need a # 4 gauge wire. check the subs conection no less than 1 ohm. check ground. and if the cap is good. 13.8 volts are for max ouput ......this is 1 ohm of charge at 13.8 volts they give 2500 watts butt only at 13.8 volts whit this relation. i¨n think you need other alternator. good look.
Feb 05, 2007 | Orion 2500D Car Audio Amplifier
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
