Question about Kitchen Appliances - Others
She was making a table of possible combinations of dried fruit to peanuts for her terrific trail mix? A.24 B.5 C.405 D.8
What foods are low in potassium?
Almost all foods have some of it, so the serving size becomes important. For a low-potassium diet avoid LARGE servings of
- whole grain bread, brans, granola
- sports drinks, all milk products, soy milk
- apricots, avocado, bananas, melons, oranges, pears, dried fruits
- baked beans, raw cabbage, raw carrots, olives, potato, pumpkin, spinach, tomatoes, most bean types
- clams, most fish, most beef types
- salt free soups, low-salt and salt substituted foods = avoid these completely
- peanut butter, peanuts, chocolate
Note that this list is NOT exhaustive and can be eaten in smaller quantities, 1/2 cup or so.
Low potassium foods are
- white flour and white breads
= cakes and pies without chocolate or high-K fruits or nuts
- apples, apricots, blackberries, cherries, grapes, mandarins, peaches (drain syrup off), pineapple, plums, strawberries
- asparagus, green beans, cooked cabbage and carrots, cauliflower, corn, eggplant, lettuce, fresh mushrooms (not canned), onions, green peas, zucchini
- chicken, turkey, tuna fish, eggs
- almonds, cashews (1 oz)
- cheddar chesse, cottage chess (1 oz)
Again this list is NOT exhaustive. For complete info see a dietician, or do an exhaustive Google search eg
Jul 24, 2016 | Cooking
I have an old food dehydrator, the brand is Quality Special Products. Does anyone have a manual or other info about this model please?
as you did not provided model - general advice only can be given.
you need to experiment aa bit - drying time on the soft fruit depend on weight, usually you calculate 1hr/1kg(2.2lb) on 50% settings. this depend as well on the size of the fruit, little plums and apricots will be ready within 1hr, especially if stones are removed and fruit halved.
apples and peaches, if cut in 6ses or eights - will take same about amount of time.
whole tomatoes, halves of pears or apples will take about 1h30min to even 2hrs per kg (2.2lb).
pulps and liquids take at least 2hrs per kg, and leathers up to 3hrs.
if there is temperature regulator on your dryer, then set it up at between 50 to 60centigrade (120 to 140 Fahrenheit),temperature above 70c (160f) will seal and prevent drying.
dried fruit should be not too hard, easy bend without cracking and no feelable moisture.
prepare fruits by washing them in following solution: juice of 1 lemon, two spoon of honey (can be sugar but I love honey), four cups of water, mix well and soak fruit cuts in that solution - will prevent blackening (oxygenation) of the surfaces, honey will prevent spoilage, it is antibacterial.
drying meat - slices should be not thicker than 10mm (3/8"), it takes on average 2 x 4hrs at 70centigrade (160f), one day 4hr and next day 4hrs. it will keep meat in dry container for even few weeks, depending on weather and humidity and curing method.
prepare meat same way as fruits, but add your favourite herbs as well, including two table spoon of coarse pepper, one spoon of cayenne, and if you like peri-peri or dried chillis, 4 to 8 cloves of finely chopped garlic add immensely to the taste as well, add at least 1.5 cup of salt to the solution. keep your sliced meat in it at least 4hrs (in cold storage!), overnight it will be better.
hope this will help you - do not forget to vote :-)
Apr 11, 2015 | Kitchen Appliances - Others
Cuisinart DLC-10S food processor leaks when liquid is above blades
Yes. It's the basic physics of all liquids.
Perhaps a blender might be a more suitable tool?
Generally you would use the food processor for mixing/blending/chopping all the dry ingredients (and maybe the butter if you are making something like cookies).
Separately mix all the really wet ingredients together in a mixing bowl/large measuring cup.
Then combine the dry ingredients from the food processor with the wet ingredients in a mixing bowl (you can fold the dry into the wet if you used a bowl to mix the wet ingredients together. If you used a measuring cup for the wet, then it's usually better to put the dry ingredients into the mixing bowl first, making a depressed area in the center, and then add the wet into the dry.)
Nov 28, 2013 | Cuisinart DLC-10S Pro Classic Food...
I have family coming over this weekend. I want to make for them a delicious fruit salad; I am just not sure what fruits to put in. Can you recommend me what fruits to use?
The fruits I use in my fruit salad are: bananas, oranges, grapes, apples, pear, and pomegranate. My family always loves this combination of fruits!
Jan 17, 2013 | Cooking
I broke one of the edges of my ping pong table how do I fix this
This is just an idea. Make a 90 degree angle out of paint stirrers. Connect by using a staple gun. Make sure that there's a bottom on it. Clamp your jig to the table so that it will stay stable. Since it is in the middle joint you can take some styrofoam packing peanuts and squeeze them in there tightly. You can choose what kind of adhesive you use. as long as its very pliable (more like liquid) but will dry hard. you can take a sander to it after it dries to make it smooth.
Dec 30, 2012 | Kitchen Ranges
What foods should I put out to feed birds during winter months?
Try to feed them food with a high fat content like peanuts and other seed mixtures high in oils. You can also feed them certain foods from your kitchen such as cooked potatoes, pastries and dried fruits.
Aug 29, 2012 | Allied Precision Birds
What freeze dried fruits are available?
You can buy plenty of different freeze dried fruits: bananas, apples, apricots, strawberries, blueberries, dried mango, pineapple, raspberry, and more. You can buy freeze dried fruit on this website:
Aug 12, 2012 | Camping, Backpacking & Hiking
Is freeze-dried food healthy?
Freeze dried fruit can be a nutritional boon to anyone who wants to maintain a healthy diet through all four seasons, because some fruits are only available seasonal. Some freeze dried fruits will not maintain their full amount of vitamin C through the drying process, but when a fruit is fresh, you can be certain that it contains the maximum possible nutritional value. In addition, fresh fruit contains a large quantity of water, which helps you feel full and satiated while it helps your system stay hydrated and efficient. Although some freeze dried fruit is slightly lower in vitamin C, research suggests that the vitamin and nutrient content of freeze dried fruit remains roughly similar to that of fresh fruit. There are advantages to both fresh and freeze dried fruit, so whichever fits more conveniently into your lifestyle and dietary habits is the right choice for you. Whenever fresh fruit isn't practical or available, you can chow down on a piece of freeze dried fruit and revel in the knowledge that you are doing right by your body.
Jul 10, 2012 | Camping, Backpacking & Hiking
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
