Portable air con making loud noise how to fix it
hvac1960
  • 2133 Answers
SOURCE: hotpoint portable air con model
Fan-blade (Propeller) may be broken. Or bearing on motor. or seating bushes loosen or worn out. Check and rectify.
Posted on Jan 27, 2011
  • 230 Answers
SOURCE: Air con makes a loud
Its the reversing valve shifting, it normal and you will hear it in the heating mode as well, you will hear it in the heating mode as well, during a defrost cycle.
Posted on Jul 04, 2011
  • 20 Answers
SOURCE: Is there any experienced technician for my portable air con in parkland, FL?
Sounds like your AC needs service. Checkout this Cool Company,Tri-County AC
Posted on Mar 06, 2013
  • 6 Answers
SOURCE: air con trips off
to be honest I have recently purchased one for 20 bucks that was doing the same thing except mine is a 11500 btu cv-2p12sx and I figure out why it kept shutting off after 1 or so minutes I have no remote with mine and what you need to do is go to your unit while its plugged in and off press and hold the power button until it beeps and when it does unplug the unit from the wall let off of the button and do it again except this time when you turn it off keep holding the button in and plug it back in and all of the light should light up on your unit then it is ready to operate hope this helps they tried to charge me and tell me it was something else
Posted on Jun 22, 2013
  • 131 Answers
SOURCE: Kelvenator split system air con has a loud banging noise from outside. I think it may b the fan as it's banging on something. How do I fix it
Start the air conditioner and physically go and have a look. You should be able to see and hear what is causing the problem. If it is the fan, assuming there is nothing caught, then something has changed to cause the 'Banging' sound. Either the cowling has moved or a fan bearing has collapsed etc. Once the cause has been found, then that's another question on how to fix. Cheers.
Posted on Dec 14, 2016
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
Making loud screeching noise
check drive belt driving altanator and air con it sounds like it needs adjusting
Dec 30, 2013 | Saab 900 Cars & Trucks
Hotpoint portable air con model mac 155..makng loud banging noise when on cool, sounds like a fan inside hitting something
Jan 27, 2011 | Heating & Cooling
I have a loud engine noise--somewhat high pitch whine--except really loud and only after so many rpms. The noise happens when I am running my air conditioner. Ten to 15 miles after I first noticed the...
So when you turn off the air con the noise stops ..
If yes then its the bearings in the Air Con pump which is driven by the same belt and when turning the r13 coolant around the bearings being dry and worn out will start to make the noise Same as the water pump does when it goes, but yours is Air Con Pump.
DONT TAKE IT OFF YOUR SELF. RON
Nov 11, 2009 | 1996 Dodge Caravan
Problem with 2006 Suzuki Swift GLX Air con
mm sounds like the air con is in need of an overhaul take it to someone who specialises in aircon to be checked out hope this helps you
Apr 01, 2009 | 2006 Suzuki Swift
Makes loud noise when first turned on
It may have been damaged in shipping or from the manufacturer. I would consider exchanging it for a new one.
Jun 15, 2008 | Danby Portable Air Conditioner
Exhaust fan making loud noises
Still under warranty. put it back together and don't tell anyone you took it apart. Call the factory numbers and have them fix or replace it...let us know what happens..kraxytech
Sep 11, 2007 | Windchaser PACR10 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
