Question about Sony Cyber-shot DSC-W55 Digital Camera
Lens stuck out and need to go back in
My lens is stuck out and when i turn it on it beeps i want the lens to go back in
    President:
  • 672 Answers
Internal lens mechanism is jammed. Have the camera repaired by a professional.
Posted on Jul 20, 2009
The lens is stuck inside and dosent come out
try taking the battery out and wait for 10 seconds and replace and see if that helps
Jul 14, 2012 | Canon PowerShot SD1300 IS IXUS 105...
Camera beeps and turns off and lens won't retract
Lens error / Battery expire.
1. Use a new battery will fully charged and then use it. Hope you get good result.
2. Some time lens zooming gear getting damaged by dust. if that gear is scrached by dust then your lens can't work and it will stucked. Your camera automatically turn off.
Of those 2 85% chance of poor/ long time used Battery & 15% chance of lens zooming gear damaged.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Cameras
The camera is not turning on. The lens is out when it should be inside when its turned off. It keeps beeping when i try to turn it on but it will not switch on.. constantly beeping.
Sounds like you've got a lens error and the beeps are signaling your lens is stuck. With the camera laying on its back, try tapping the lens ring while pressing the start button. You may just luck out. It's about all you can do without taking your camera apart.
Dec 11, 2009 | Microwave Ovens
Lens stuc and makes beep sound
I had the same problem and my brother just wiggled the lens shut carefully while turning the power on at the same time , it took about 5 tries and finally had the lens was all the way back in place and it works great.It was just the lens was stuck open and would not start up like that I guess. better then junkin it.
Sep 01, 2009 | Samsung BL103 Digital Camera
Samsung bl103 will turn on and beep 3 times then pauses and beeps 3 times again and the lens is stuck in the out position
Mine does the same thing. I open the battery door and close it back up. Then I push the power button and the lens will retract. When I turn it on afterwards it works fine. Mine does this quite often.
Jul 22, 2009 | Cameras
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
E18-lens stuck out-not fully out-won't budgein or out any further
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. As you've dropped it, you might need to start with Fix #7:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Sumsung digimax
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time you will hear a clicking noise which is normal once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Jan 14, 2008 | Samsung Digimax S500 Digital Camera
It turns on but then turns off
You need new batteries... My camera did the same thing
Dec 15, 2007 | Polaroid I533P Digital Camera
Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Oct 05, 2007 | Samsung Digimax S630 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
230 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
