My CD tray will not stay open - Audio Players & Recorders
    Top Expert:
  • 7,437 Answers
Owners manual
Place a flatblade screwdriver in the lower lip of the drawer, and manually force the tray out. It is okay to pull, you won't break the tray. It rides on a straight rail gear. After pulling on it, it should eject normally, but stay open. If it closes right away, there must be some blockage within the case. Using a flashlight, check to make sure no foreign object is blocking the tray. If the tray stays open, that is a good sign. Push it in and see if it closes on its own. Try pushing the button to eject. If the tray does not come out, take it in for service. If it comes out, perhaps the problem is solved.
Jan 26, 2014 | Sharp CD-C401 Shelf System
I have a CDX-602 CD Player. I was on a gig the other night I placed a cd in the tray. I pressed the button to close the tray and a cord was wedged so that the tray would not close. Naturally the tray...
The gears have probably come out of sync, meaning the tray is riding on the limit switch. You need to remove the deck, dismantle and re-sync the drawer mech. Check the limit switch isnt bent, it's quite flimsy
Aug 21, 2010 | Philips Gemini CDX-602 Dual CD Player with...
Cant load cd into cd drive
Sounds like the tray is not comming out completly. Before you eject the tray you should notice a very small hole. take a paper clip and straighten it out and push in this hole. The tray will/should start to come out push the paperclip in as far as you can and check to see if this will allow the cd to stay on the tray.
Mar 31, 2010 | E-Machines eMachines Desktop PC
Cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
regards
3rq8 (Triarcuate)
Mar 31, 2009 | Sony CDP-C265 CD Player
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
Cd tray on my 360 wont stay shut
either you will need it repaired or u can do it the cheap way and after the disc tray is shut put some tape over it and see if it will read it still. If not it will need to be repaired. It will only cost about $35 or free if you are still under warranty.
Feb 14, 2008 | Microsoft Xbox 360 Console
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Cd tray remains open
you need,tray alignment or electronic failure,see a doctor.
Feb 01, 2007 | Panasonic SC-AK200 CD Shelf System
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
 Grubhead
Grubhead
