Question about Luminara 7 Ivory LED Candle
I have a one year old candle that has sat on my mantel and turned on maybe 6 times all year. It wouldn't work so I changed the batteries (3 different sets) and still nothing. Any suggestions??
  • 18,313 Answers
Made in China. Unfortunately, throw it away.
Posted on Dec 14, 2016
I have a 5-year old Garrison smoke alarm. The LED does not flash every 45 seconds as the manual says it should, but the alarm sounds when I press the test button. Is the alarm working properly or not?
They recommend changing every 10 years so it is well in date.
Light 4 candles, and blow them out 6" under the smoke detector. If the alarm goes off, it is working :>)
Nov 27, 2016 | Home
I have two I believe they are candle holders on the bottom there is a label with underwriters laboratories,inc listed electric fixture issue no. C-531,937 E-36685 can you tell me anything about these...
unless there solid silver or gold , im affraid there only worth how much you like them !!!, Now if they were gas light candle mantels then thats a different story , lots of folks restoring old homes are looking for them !!! highly sought after they are
Mar 01, 2015 | Heating & Cooling
Had to get a jump car would not start had battery wiring altnator check not that battery is only 6 months old car can he site to start now today car starts but 4 times stalled while idling at different...
run fault codes to check for faulty sensors. Batteries have no specific life span and 1 day to 4 years is any time that they can fail in. Have the battery load tested to ensure that all cells are ok
Jan 09, 2014 | Chevrolet Cars & Trucks
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
My 96 Grand Charokee sat for 3 years. I can't get it to start.
What about the fuel, was it drained and the system flushed. Gas turns to goop after this long and will barely burn.
Apr 13, 2012 | 1996 Jeep Grand Cherokee
Scooter sat for a year; wouldn't start; replaced battery. filled with gas. cleaned spark plug. won't start. Help
after a year sitting idle chances are that the gas inside the carb has degraded and the carb will need cleaning also when you filled the tank did you remove any old fuel? if not the its contaminated with the old gas
give it a full service new feul clean carb clean air filter then it should start
hope this helps
Jun 30, 2011 | Aprilia Scarabeo 50 Four Stroke...
2001 Ford Windstar Battery light came on when driving by the time we got home all of the dash board lights were on. Turned engine off and it would not restart, sounded like dead battery when tried...
Hello and welcome to FixYa!
As a first course of action, I strongly suggest that you have the battery charged. It can be an indication of a weak battery or a faulty alternator. If the battery light still on after charging then the problem will surely be on the alternator itself. If that's the case the alternator should be replaced to resolve the problem.
You may try to reset it to by removing the positive battery connector, letting it sit for at least 5mins. then reconnect it again. This will reset the system and can get the battery light off.
Hope this helps and thank you for using FixYa! Have a good one!
May 12, 2011 | 2001 Ford Windstar
Just curious
Ours did...did yours? Our insurance company is trying to hold us liable to our deductable since I had a Candle on our mantel. The Candle was no where near the TV. When I found the TV on fire it was coming from the back of the TV.
Jul 28, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
How do I change the time?
The Macrotel Excel, Macrotel MT-16 and the Prostar 816 are all very similar in programming. The following information should work on all 3 KSU's of any revision or software level.
To Enter programming: Must be done before any programming
Depress # (Programming)
Dial 20 (MMC Disabled)
Enter Password [Default is 1234] {or it may be 4321}
Dial 1 to enter programming mode. Programming mode will turn off automatically after a few minutes of non-use.
Dial # again
To change Time and Date:
# (Programming)
Dial 55 (YY MM DD W HH MM)
Input new data:
YY= year
MM= month
DD= day
W= weekday [0=Sun 1=Mon 2=Tue 3=Wed 4=Thu 5=Fri 6=Sat]
HH= hour (24 hour mode)
MM= minute
All data must be entered each time or changes will not be saved.
Dec 04, 2007 | Samsung Prostar 824 Keyset Telephone
Luminara 7 Ivory LED Candle Logo
264 people viewed this question
Top Luminara Home Experts
john h
Tom Chichester
Are you a Luminara Home Expert? Answer questions, earn points and help others
