Question about Cell Phones
Sim card where is it so i can check it - Cell Phones
  • Cell Phones Master
  • 20,929 Answers
Not ALL phones have SIM cards, I think it is GSM phones that don't.
On an iPhone they are on the right side. You need to insert a tool and push it for the door to pop open.
On Samsung phones, the SIM card is under the battery.
Google
make model remove SIM
Google
Posted on Dec 14, 2016
Put in sim card and comes up insert sim ?
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Nov 02, 2012 | Cell Phones
HTC SNAP SIM CARD FAILURE
First All Check:
Last Option:
Sep 01, 2012 | Cell Phones
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
Nokia 6120c simcard rejacted
There are some possible solutions:-
1. Check that your sim card is in perfect condition by putting the same sim card in any other mobile if the samemessage appears that means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by inserind any other sim in your sim card's slot if the same message occurs that means the problem is in your sim card's slot
3. Check that whether you are inserting your sim card correctly or not
Nov 20, 2011 | Nokia 6120 classic Cellular Phone
Insert sim solution
1. Check that your sim card is in perfect condition by inserting the same sim card in any other mobile phone if it shows the same message then the problem is in your sim card
2. check that te slot of sim card is in perfect condition by insering any other sim card in your phone if the same message occurs then the problem is in you sim card's slot
3. Check that you are inserting you sim card correctly or not
Sep 01, 2011 | Nokia 6120 classic Cellular Phone
Solving the nokia6120c insert sim problems
1. Check that your sim card is in perfect condition by insering the same sim card in any other mobile phone... If the same message appears that means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by inserting any other sim in your mobile phone... Still if the same message occurs that means the problem is in your sim card's slot
3. Check that you are inserting your sim card correctly or not
Aug 27, 2011 | Nokia 6120 classic Cellular Phone
No sim card
Nokia C3 mobile shows no sim card means:
1.Might be your sim card got corrupt
2.Sim card slot in your handset may be damaged
3.Sim IC got damaged
these all are the reason for this problem
soluion
1.Check your sim on other mobiles.
2.Change you Sim slot after checking it.
3.Lastly check your SIM IC if neccesary change it
Aug 17, 2011 | Nokia C3 Cell Phone
When i am switching on my phon....it is written in the screen that SIM CARD NOT VALID why??
1. Check that your sim card is in perfect condition by insering the sim card in any other mobile phone... If the ssame error appears then it means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by insering any other sim card in your mobile phone... If the same error occurs then it means the problem is in your sim card's slot
3. Check that you are insering your sim card correctly or not
Aug 06, 2011 | Nokia 6120 classic Cellular Phone
Sim card
How to correct sim card error / insert sim card
Procedure to follow
Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it
Step 2: If the sim seater/tray is not broken, clean the entire terminal.
Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray.
Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem.
Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
Insert sim card issue
just insert another sim card and check whether that sim card is working. also put your sim card in to another phone and check whether it is working.
Jul 27, 2009 | Nokia 6070 Cellular Phone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
