Question about Cuisinart Coffee Makers & Espresso Machines
How do I get a replacement for the Cuisinart food processor recall? Phones are tied up and I can't get on the website.
  • 5 Answers
SOURCE: cuisinart food processor
I went through the same thing...as it turns out, everything was locked into place but I had the handle in the back rather than the front where the sensor is. Good luck. I hope that helps you.
Posted on Feb 06, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Posted on Mar 17, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart
Make sure the Pusher sleeve lock switch is unlocked, and then push the clip that says "Push here" inward and lift up. If this fails, send in to Cuisinart for repair (call first), or break the bowl, etc and re-order the parts (drastic and expensive, but effective).
-Tha Mp3 Doctor
Posted on Mar 20, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
Posted on Mar 23, 2009
SOURCE: need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Posted on Sep 15, 2009
Need new blade for food processor
Just Google
make food processor blade
They are available from eBay, the manufacturer and appliance specialists.
The is currently a recall on Cuisinart FOUR rivet food processor blades, and they will replace for free. Reply as a COMMENT if you need details.
Google
Jan 03, 2017 | Food Processors
What to do with Cuisinart processor #dlc-2007 that was recalled
Don't use it. Contact Cuisinart and they will send you a new blade. The recall is on the blade only.
Conair retira del mercado procesadores de alimentos Cuisinart debido...
Dec 14, 2016 | Cuisinart Food Processors
CUISINART RECALL PART DFP 14
Cuisinart Food Processors Recalled by Conair Due to Laceration ...
https://www.cpsc.gov/Recalls/2017/Cuisinart-Food-Processors-Recalled-by-Conair
  1. Cached
13 hours ago - This recall involves the riveted blades in Cuisinart food processors with model numbers that begin with the following: CFP-9, CFP-11, DFP-7, ...
Cuisinart Recalls 8.3 Million Food Processor Blades Dating Back To ...
https://consumerist.com/.../cuisinart-recalls-8-3-million-food-processor-blades-dating-...
  1. Cached
7 hours ago - Yet Cuisinart has recalled 8.3 million food processors in the United States and Canada that pose a ... Affected models: CFP-9, CFP-11, DFP-7, DFP-11, DFP-14, DLC-5, DLC-7, DLC-8, DLC-10, ... Part of Consumer Reports.
DFP-14 - Food Processors - Parts & Accessories - Cuisinart.com
https://www.cuisinart.com/parts/food_processors/dfp-14/
  1. Cached
DFP-14. White And Stainless.Png Color Swatch Matte Black Metals.Png Color Swatch Brushed Stainless.Png Color Swatch White.Png Color Swatch Red.
Dec 14, 2016 | Cuisinart Blenders
Where do I register for replacement blades for recalled blender blades?
Dec 14, 2016 | Blenders
Saw on the news that my Cuisinart food processor has been recalled. So, what do I do now?
Cuisinart toll-free at 877-339-2534 from 7 a.m. to 11 p.m. ET Monday through Friday and from 9 a.m. to 5 p.m. ET Saturday and Sunday or online at www.cuisinart.com and click on Product Recalls at the bottom of the page for more information on the voluntary recall.
Dec 13, 2016 | Cuisinart Food Processors
Cuisinart Food processor
Go to the cuisinart website and you can buy replacement parts. You will have to buy the entire shaft not just the top but it is still good!
Mar 25, 2008 | Cuisinart DLC-10S Pro Classic Food...
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
