Question about Panasonic Televison & Video
Panasonic dmr ez48 dvr optical laser assembly repair replacement
How hard is it to replace an optical laser assembly or to get the dvd recorder itself not the whole dvr replaced
SOURCE: Panasonic DMR-EH75V DVD Recorder
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Posted on Apr 02, 2008
  • 848 Answers
SOURCE: I have a Panasonic DVD
Take out the 3 screws holding the DVD drive top in place. And then move
the drive head mechanism back (pushed it towards the back of the unit).
Then plugg the power in, turn it on . This will remove the u61 error code .
Posted on Jul 20, 2008
SOURCE: Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Posted on May 08, 2009
  • 50 Answers
SOURCE: OPERATING ISNTRUCTIONS FOR PANASONIC DMR E55EG DVD RECORDER
Here is the english manual..
http://service.us.panasonic.com/operman/findmanual.aspx?cat=DVD
Use a pdf reader to open the file..
Jay
Posted on May 30, 2009
SOURCE: Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Posted on Jul 25, 2009
I have a Panasonic DMR-EZ48 it will play for a short time then it freezes up and the only way I can un freeze it is to press and hold the power button for 30 sec then it will play but repeats the problem....
Is the media a commercial CD/DVD? Some copies made on another recorder or computer do not work well with devices other that one the copy was made from. In short, the angle of the read head may differ from the Panasonic DMR.
Jan 22, 2015 | Panasonic DMR-EZ48 Dvd/Vcr Combo Recorder...
Where can I obtain a replacement DVD recorder for my Panasonic DVD Video recorder DMR-75V. It is not operating and wont read discs, record or erase. Can only play sometimes. Would need to operate in...
FIrst of all, try cleaning the lens using a cotton swab and alcohol. Once complete, try a DVD and then a CD. If the CD plays and the DVD does not, the optics are failing and need to be replaced. If you are comfortable with this repair, the parts should be available from any Panasonic parts distruibutor in your country. I can only get part numbers for American units. The optics should be the same for the Austrailian units, but I can't verify this. Call a the parts distributor and ask for the optics assembly. This will be the assembly that contains the optics, the sled motor and the frame. This will be held in place by 4 screws.
Good luck.
Dan
Jul 01, 2008 | Televison & Video
On A dmr.ez48v on schedule a program on the speed on how mu ch time is left at the top of screen how do you change the speed
On the remote at the bottom next to record is RECMODE this changes the speed. You will have to select each recording you want to alter to change it I think.
Oct 20, 2014 | Panasonic DMR-EZ48 Dvd/Vcr Combo Recorder...
I have a Panasonic DVD recorder model DMR- ez48V. It keeps giving me the 'no read' message on display. I cleaned the laser. Is it possible the laser assembly is bad? If so what is the part...
I have the exact same model with the exact same problem. The motor on the dvd drive went bad. No spin = no work :-( Good news is that the dvd drive is easy enough to replace. Bad news is that I can't find a replacement drive - not a standard PC style drive...
Jun 30, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I HAVE A PANASONIC DMR EZ28 DVD RECORDER AND IT WONT READ ANY DISC CAN YOU HELP PLEASE NOT EVEN A LENS CLEANER
The 'No Read' error is a classic case of a failed laser (and/or DVD drive). In many Panasonic DVD devices (recorders, players and some Blu-Ray models) the laser is part of a traverse unit or 'assembly' (a block with laser and spindle motor in one). With this unit, unless you are tech. savvy and are aware of the likely cost(s) of replacement part(s) for this type of product, you can go ahead and order from Panasonic directly - subject to shipping and tax (assuming the part is available) - this could be expensive, and you would also need the right equipment/tools and experience to do this (it is much easier to simply replace the whole DVD drive itself in the unit - just note the original drive number and connection type before seeking a new one, after that - should be a straightforward fit, save on labour costs...) - these drives are not exactly easy to repair at individual component level; hence why in most cases the whole drive is replaced when part of it fails (not impossible to replace either!).
If you aren't familiar with this sort of thing, your next best bet is to submit the recorder to an authorised Panasonic service centre, obtain a (reasonable) quote on likely repair/part(s) cost(s), along with a second opinion, then you can make a firm decision on that basis. Up to you whether you pursue it further or not. The DMR-EZ28 is not as old as the DMR-ES15 and is more reliable in general. Assuming this can be repaired, it could be very expensive, so keep that in mind, but you won't know for sure unless you get a quote from a workshop. It may also take several weeks before repair (if possible) is completed.
If all else fails, or it is probably going to be too expensive/uneconomical to fix, or you cannot get a replacement DVD drive anywhere for this model, then consider a new one - but ONLY as a last resort. The cost of replacing a disc drive in your existing unit vs. the cost of a brand new machine could be significant.
Not the best news, but certainly worth investigating - if you want to do so.
Mar 24, 2011 | Panasonic DMR-EZ28K DVD Recorder
Dvd drive motor won't run
Hi, Please check the power supply / feed to your motor, use the volt meter. If there is no power then the motor is damaged and need replacement. Check also the 'fine' cables for kinky and burr.
Regards, jay
Jan 21, 2011 | Panasonic DMR-EZ48 DVD Recorder
DVD optical drive does not play all dvds all the time .one time it will play(same DVD)next time it won't.Also sometime finalize failure.Finally tray will not close w/dvd in the tray(sometimes).Is there a...
It sounds like the DVD-RAM drive is about dead. Panasonic did not make them to be very durable.
Panasonic sells replacements at a high cost.
Replacement drives may work from used models including:
DMR-ES15
DMR-ES25
DMR-ES45
DMR-ES46
Oct 01, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
What a story ! Clean your laser eye with Rubbing Alcohol and a Q-Tip. Down updates to your Recorder from Panasonics Website., and install in your Recorder. Order your replacement parts from Panasonic but I do doubt you will need them.
Jun 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Jun 02, 2008 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
93 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
