Question about Microwave Ovens
Microwave 1100 watts loses power shuts down when cool powers up again
    Top Expert:
  • Microwave Ovens Master
  • 48,219 Answers
Take it in for a proper diagnosis
could be a problem component on the circuit board or magnatron failing
Posted on Dec 14, 2016
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
What is watts for goldstar MA 1280M Microwave and if it is over 1100 watts cani i adjust it down
You can set it to different levels. It is doubtfull the magnetron will deliver more than 750 Watts as that is about all they can produce singley. Commercial ovens use at least two magnetrons.
Most specs on microwave ovens quote the power drawn not power produced.
I hope that helps.
Jan 01, 2011 | Goldstar MA-1280M Microwave Oven
GE spacemaker - JVM 1653 SH unit shuts down after power up. Start back again when cool? Do I scrap it or is it repairable?
For most microwave problems it will cost more then is practical to make repairs to them...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 19, 2010 | GE JVM1650 1000 Watts Microwave Oven
My JVM1653 loses power after 3 minutes of heating
it may have been the hi voltage at the magnetron,but the shut down is your heat thermocouple mounted on the magnetron side and when the mag overheats this thermocouple opens up and shuts off power to the mag to prevent overheating and fire
Apr 17, 2010 | GE JVM1650 1000 Watts Microwave Oven
Microwave shuts down when hot
Most microwaves have a temp sensor or moisture sensor. Maybe your one has gone faulty or the magnetron itself is causing it to shutdown. Get it checked up.
May 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Trouble shoot microwave
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Also, are any other of your electrical items (light bulbs, DVDs, etc.) failing lately? This could indicate improper power line voltage.
Let us know if the hard reset doesn't fix it.
Jul 18, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
Dandy Designer 800 Watt Microwave
I would suggest that you try it for a minute or so on the very lowest power level and see if it shuts off. If so, please post again with more detail about how it fails, such as whether it loses all power as if someone unplugged it or just acts as if someone hit the STOP button.
Apr 15, 2007 | Danby DMW773 Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
