Question about Toro Garden
Toro Powerclear 180 carburetor adjustment. - Toro Garden
2 Suggested Answers
  • 122 Answers
SOURCE: where am i able to get an owners manual for toro
I believe you can find it from the link below:
Posted on Feb 02, 2011
How do i trouble shoot the electric starter system,it does not work
Mine the electric cord had pulled out of the receptacle.on the blower so it was not working. I pulled it right out and reinstalled it It's ok now.
Do you have power coming to the blower or have you blown a GFI and it needs to be reset. Does the starter click or try to work? These are things that I have to know before we tear things apart.
If it buzzes it could need a gear replacement. on the starter itself.
Mar 03, 2015 | Toro Powerclear 221qe Electric Start...
Snowblower leaks gas on garage floor
Is it coming from the carb or tank? Either way replace the fuel lines, they crack an get pin holes in them an cause problems. If it comes from the carb get a rebuild kit an, very cheap, an replace the seals.
Feb 28, 2014 | Toro Powerclear 221qe Electric Start...
Idle adjustment
I do not think this will cause any damage. If it starts and runs fine I think you did a good thing.
Nov 06, 2013 | Toro Lawn Mower With Toro Power Tools
What is the high altitude adjustment required by the manual?
the high speed adjustment needs to be richened up to compensate for the lean air mixture at high altitude. it can run but will run fast and may damage the unit because it is lean. the high speed adjustment is the one marked H or the screw farthest from the engine. turn it counter clockwise while running at full speed until it runs at the correct RPM. any small engine repair center should be able to do this for you and keep you from causing irreparable damage
Feb 27, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
I have a Toro Lawn Mower with a Tecumseh LV148EA-362003C engine. It is Idleing very high and can't seem to adjust it down. How do i do that and what would be the cause
I could not find a listing for the full engine model number, but there are a lot of engines that start with LV148EA. The good news is that I glanced at the part number for the carburetor on about a half dozen of these engines and they all use the same carburetor. Assuming that you have the same carburetor on yours that the others have, I was able to pull up an illustrated parts drawing for the carburetor. By studying this drawing and a TecumsehPower carburetor manual I was able to determine that you should have a Series 11.
I have been doing some research on your problem, before you mess with any adjustments you should check a few of other things first. One is to check that the bowl gasket is not bad. Two is to check that the fuel pickup is not restricted. Three is to check that the idle port is not restricted. The first one requires just taking the bowl off to look at. The others require removing the carburetor to inspect and clean.
If none of those remedies corrects the problem, then it should be time to adjust the screws.
I hope this helps.
Aug 03, 2011 | Toro Lawn Mower With Toro Power Tools
Tecumseh 6.5 Hp engine pulsates and dies
the adjustment screw is on the side of carb above the fuel bowl turn it all the way in & back it out 1-1/2 turns out that should set the carb.let me know if i can help further thanks wade
Jul 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
165 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
