Question about Cameras
Dust indicator on the digital display of 450E is showing an unhappy face and is showing the top level of dust pollution all the time.
  • Marion Warner-Smyth
    Marion Warner-Smyth Dec 14, 2016
    Is this a fault?
  • Brad Brown Dec 14, 2016
    Is this an Olympus or a Minolta? The models are E450 and 450E
  • Cameras Master
  • 18,239 Answers
You need to take it in for cleaning and service or fix yourself. It sees dust on he sensor or lens. You can try removing the lens and use a puffer brush. The manual also tells you how the system works and how to clean yourself. The is a Cleaning Mode on the Camera.
Page 14 of manual. Page 111, and 112.
Posted on Dec 14, 2016
Why is there an anti-pollution fault on first start followed by management light on?
It's not unusual for 207s to show the anti-pollution warning randomly. In my experience it isn't significant and you just learn to live with it, but as yours is consistently showing at start up accompanied with the engine management light, it maybe something more serious. If the car appears to be driving okay, then I would be inclined to ignore it, if not, you will have to have a Puegeot dealer put it on their computer diagnostic machine - pricey !
207s have a bad reputation for random fault indications as a whole (Google it), some of which seem to be ambient temperature related - my father's 207 randomly shows the air bag light on very hot days but this goes away after a few start/stop cycles and a drop in temperatures. Fortunately, his MOT is due in March so when it goes for an MOT the light is always off - air bag fault indication showing is now an MOT failure.
Some people wouldn't be happy driving with an air bag indication, or any other fault indication, showing even for a short period of time, so this is a personal decision as to what you do about it.
Apr 04, 2015 | 2007 Peugeot 207 1.4
Still getting dust build up after installing an IQ air system
You will need to run an actualy HEPA filtered air filter as well. The air purifier will oxidize pollutants and will attract and trap some small dust, but most small units also require additional filtering to trap inert neutral charged dust.
Feb 03, 2012 | IQAir Air Purifiers
I have a lot of dust on the furniture
You should run a seperate HEPA filtration unit as well. The purifier normally oxidizes organic pollutants, and will attract some small charged dust, but not everything.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
I believe I must have let dust come in to my sensor when I used it on a desert safari. How do I check it?
Shoot a light colored blank wall at F22....if there's dust, it will show up. Google the words "how to clean a DSLR sensor" and you will find sites explaining the procedure and places to obtain the supplies needed.
Feb 01, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Dust filter has indicated extreme level of dust for several days making the fan stay on high. any way around having it professionally repaired?
- Remove the top two screws from the control panel.
- Remove the control panel. Be careful not to pull to hard as there is a ribbon cable taped into place.
- If the ribbon cable is taped, remove the tape and set down the panel as to not put weight on the ribbon cable.
- On the top left side of the unit (behind the dust sensor), there is a small box that is held in by a screw and plastic clips. Remove the screw and put tension on the clips so you can remove the box.
- there should be two holes in the box (one on each side), use a cotton swab and alcohol to clean outside and inside the box. I reached inside with the wet swab as far as it would reach.
- While you are in there, take some time to remove as much dust off of the front panel and anywhere else it may be.
That did the trick for me.
Dec 24, 2010 | Kenmore EnviroSense 85501 Air Purifier
My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
Samsing M100 Digital Camea Lens not working
May be some dust particles are stuck. use the vacuum cleaner to suckout the dust from between the bady and the lens casing. Suckout and not blowin.
Aug 24, 2009 | Samsung L100 Digital Camera
Picture come out with black dot inthe middle of the picture
If Alex's comment didn't resolve your problem, check for dust inside the camera body and on the part of the lens that goes into the camera body. The highlight indicator he speaks of will show on the LCD screen, but should not show up on your final picture once downloaded from the camera. Since the optics on that end of the lens are smaller, they are more susceptible to dust and dirt. If there is dirt or dust inside the camera body and you are not familiar with how to clean it, same yourself some headaches and take it to a qualified camera shop. You can seriously damage the interior optics of your camera by attempting to clean it the wrong way.
May 12, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Spots on Rebel XT image
Dust is something that will need to be addressed. Get a Visual Dust brush and learn how to use it. You can help reduce dust by 1) changing lenses with the camera body facing down and 2) turning off your camera when changing lenses.
Sep 14, 2005 | Canon Digital Rebel XT / EOS 350D Body...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
