Question about Garden
The composition and thickness of soil depends on?
    Top Expert:
  • Garden Master
  • 8,128 Answers
When do I plant the seeds and when do I re-plant the plants, and what preparations have to be done to the soil?
All good questions but unfortunately none can be answered. When you plant depends on the plant itself and where you live. Southern regions get warm earlier than northern regions. Same applies for replanting. Soil preparation also depends on what you are planting, some plants like the soil acid and other prefer alcaline.
Feb 07, 2017 | Garden
What do you furtlise Hydrangers with?
I love these plants for their ease of growing and spectacular colours!
The answer to your question partially depends on what colours you have or want. Other than that they pretty much grow anywhere in a good sunny spot, and unless your soil is terrible, they dont need fertilising, just plenty of water. If you do fertilise then everyday fertiliser is fine but depending on its composition it may change the colour of the flowers.
This excerpt is from a web page listed below:
"Hydrangeas are amazingly versatile in that you can actually alter the flower colours to suit your needs. The flower colour in most forms relates to the acidity or alkalinity of the soil. In acid soil (pH 5 or less) hydrangeas are usually always blue. As the soil pH climbs towards the neutral and alkaline end of the scale (pH 7 or more) hydrangeas turn mauve, pink and red. A blueing tonic (containing aluminium and iron) will turn pink or mauve hydrangeas blue. It should be applied once a month in March and April and again in August, September and October, following the directions on the pack. A cup of lime (calcium carbonate) added to the soil in spring will cause blue or mauve hydrangeas to turn pink. White flowering hydrangeas will remain white regardless of soil pH."
http://www.burkesbackyard.com.au/fact-sheets/in-the-garden/flowering-plants-shrubs/hydrangeas/#.WAWfKzJg3cM
Oct 18, 2016 | Miscellaneous
How many pounds of soil for 50 gallon container
That's a loaded question,lol. It depends on the type of soil and moisture content. Also, if you are trying to figure out how much soil you need, soil is sold in square yds which would need to be converted to square feet with such a small amount needed in a barrel. Here's one conversion site:
Convert me com Instant units conversion
Apr 03, 2016 | Garden
Large stock pot leaks
The heat will only shrink, crack, or dislodge any sealant applied to ceramic or metal surfaces. A weld will work on some metal surfaces depending the composition and thickness. Some materials are TOXIC and contaminate food, so be aware of that fact.
Mar 17, 2014 | Dishwashers
Plant food question
The foliage looks very good (color, texture, freedom of insect damage, etc.). "Food" or nourishment depends on things like plant species, soil conditions (available root growth area, density, drainage, pH, existing nutrient levels, etc., etc.). Send a soil sample to your state soil analysis lab for discovering pH, nutrient levels, recommendations for soil treatments, etc. Your county Ag Agent will help you free of charge.
Mar 21, 2013 | Garden
Errore000064 occured
Power supply voltage error (high-voltage error)
The presence of a high-voltage error is communicated by the composite
power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause: The contact has poor connection. The wiring is faulty. The composite power
supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly,
or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller,
developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Jan 19, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Image source 50 code E64
E064 Error code details Power supply voltage error (high-voltage error)
0000 The presence of a high-voltage error is communicated by the composite power supply PCB.
(The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Main cause
 The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
 Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
2. Wiring
 Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
 YES: Yes.
 NO: Replace the DC controller PCB. pls rate for my good deed!!!!!!!!Good Luck
Sep 21, 2009 | Office Equipment & Supplies
Possible impulities in irrigation water
There are so many variables to answer this that more specific information is required. 1. Depends on both mineral deposits in the affected area and nearby industry that may cause pollution. 2 & 3. Depends on terrain, objectives and application. 4. Depends on type of plants desired and their tollerances to existing soil conditions. Also, economics of soil modification.
Sep 05, 2009 | Guest 503 Spot/Flood With Console Control
How to clear E000064 problem in ir3300 model
E064
Main cause The contact has poor connection. The wiring is faulty. The composite power
Action
1. Contact
2. Wiring
YES: Yes.
Feb 26, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
2. Wiring
YES: Yes.
Feb 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Garden Logo
75 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
