Question about Health & Beauty
I know how to solder,I have the battery's,how do I open it up to install them.
  • shaveroutlet.com
    shaveroutlet.com Dec 29, 2016
    what is the make and model number of the shaver???
  • Robert Henderson
    Robert Henderson Dec 29, 2016
    Model no F5790
The lithium battery to my Garmin Nuvi 350 is giving out. My husband has figured out how to open the case, and I've tracked down replacement batteries on line. The picture of the batteries online looks as...
Well when you opened the case did you see any wire connection to battery that is soldering if yes then you need to solder or if there is the wires the replacement battery they are terminals of the battery you need carefully to main board and check the battery wires and then solder it to the board...
Good luck..
Aug 07, 2008 | Garmin GPS
Ipod touch replace battery
You need to solder one in
Replace 4th Generation iPod Battery http://www.youtube.com/watch?v=v8-KUt8PVFY iPod Touch 4th Gen Instructions http://www.youtube.com/watch?v=X1B5iu3ILkY How to replace your ipod touch 4th gen Battery
Apr 10, 2013 | Apple iPod touch 4th Generation MP3 Player
How do you open the case to replace the batteries? Do the batteries have to be soldered?
On model 5865XL, remove the two screws on the back to remove the back cover. You have to slide up the trimmer to access one of the screws.
The batteries are soldered in. You will find the correct batteries at shaveroutlet.com. See link below. Scroll down the page for helpful installation videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 29, 2011 | Norelco 5865 XL Electric Shaver
My car came with two sets of keys they have a door unlock/lock button, trunk button, and one for the alarm. They both stopped working so I bought new batteries. I had put them in and it still never worked....
Re: Key Fob - U shaped battery hold down bracket. (Open key fob with a small pen knife)
This battery holding bracket commonly becomes dislodged from the circuit board when you drop the key fob due to the weight and momentum of the battery. Closely examine the bracket and notice there are three little projections that align with holes in the circuit board. The only thing keeping this bracket in place are three points on the opposite side of the circuit board where it is soldered. It is easily repaired if you have soldering skills. Obtain a 27-watt soldering iron from Radio Shack and rosin core solder. If the bracket is still partially attached to the board, heat the solder pad(s) and completely remove the bracket. Next, heat each pad and open the pad hole with a pin or tooth pick. Clean any excess solder off the bracket's mounting feet and re-solder making sure it is flat against the board. If any of the mounting tabs are broken away, remove the broken piece from the pad hole. Then solder a short piece of wire to the side of the bracket as a substitute, insert & solder to the board. Install a fresh battery and test. Caution: Do not apply excessive heat to the circuit board. Do not use high wattage soldering gun.
Jun 05, 2011 | 2005 Pontiac G6
Samsung Q25 PC Notebook - how to change cmos battery?
You will have to open the system up and replace it. They look like thiscarlo_digi.jpg
and the process of opening the system is relatively easy just set aside an hour and be patient.
Best way to find the cmos battery you need is to open it up and search the web for the part number.
Mar 01, 2011 | Samsung Q25 HXC 738 Notebook
I have a ge 7 Day Indoor in-wall Programmable Digital Timer Model # 15086 and I have nothing showing up on the screen. Any advice?
The instructions say, "Note that the screen blanks if the battery is discharged completely." It will probably charge when you install it.
May 13, 2010 | Hardware & Accessories
I opened up the case to my Norelco 5601X to replace the batteries. It looks like the batteries are soldered to tabs that go through to the other side of the circuit board. I can't seem to see how to lift...
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteriers for your model 5601X shaver at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Apr 22, 2010 | Norelco 5601 X Electric Shaver
Dv6000 443775-001 power issue
At the risk of subjecting myself to your possible wrath, I suggest you replace the motherboard. I don't know your computer repair prowess, and am not doubting it for a minute, but I 'stand' here to tell you, that it's just not that simple.
The hardware components are installed down into a bare motherboard. The leads for the hardware components are in their 'raw' state, where they hang down past the motherboard. Then the motherboard is heated up using a hot air soldering method, and the solder flows over the leads making a precise, pretty little solder joint. This is done with robotics. Once this is accomplished, the extra length of lead is snipped off.
Some components are installed by hand. Very few of them. The operator uses a soldering station, and an instrument that magnifies the area by a great amount. Looks like a binocular microscope. One, two ,three, and the next motherboard comes up, and the same part, by the same operator is installed once more.
Again, not doubting your expertise in this area, but if you have use much heat, or linger too long, you stand the chance of making the copper circuit trace, lift right off of the motherboard, when you go to remove a component. Not enough heat, and you can't remove enough solder, nor get the lead to come out of the hole. (I use solder wick. Also known as Desoldering Braid. Solder ****** tools are for the bird's! (Desoldering Tool)
Same thing with soldering a new component in place. Too much heat or linger too long,....well you know what happens. Not enough heat, or staying in position long enough, plus using the right technique, you get a cold solder joint. It's a lot of fun, when you reassemble the laptop all the way, and find this! Guess what happens next? Yep! Do it all over again!
I'm not a saleman for Ebay, but I find a lot of my motherboards for laptops on there. I would also suggest looking at -> Laptops for Parts.
Apr 05, 2009 | HP Pavilion zd8000 Notebook
Health & Beauty Logo
111 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
