Question about Coffee Makers & Espresso Machines
How to remove coil from a black and Decker double burner hot plate
5 Suggested Answers
  • 30 Answers
SOURCE: Double coil spiral plates for cookers
what the heck are you refuring too?
Posted on Jan 30, 2008
vinceisaac
  • 2432 Answers
SOURCE: black and decker steam iron #415 not hot enough - why
the contact switch for heat control not get good contact or dirty need to clean.
Posted on Nov 26, 2012
  • 51521 Answers
SOURCE: How Do I Clean underneath the coils of a Black & Decker Single Buffet Burner?
blown it out with compressed air .
Posted on Mar 30, 2015
  • 236 Answers
SOURCE: We have modern Miele induction hob not sure of model it has three single hot plate, one large double extra speed hot plate one double hot plate its in demonstration mod how can l cancel?
I am assuming the timer display is showing "dE" . If you have the manual page 50 (programming) shows how to cancel demo mode. It is program P 0, currently it is set to "0" (demo mode), you need to change it to "1" (demo mode off).
Posted on Feb 07, 2016
How do i remove a black smear on my sole plate icr 500
clean it with a sharp edged blade slightly ,only when it is hot
Nov 13, 2014 | Black & Decker ICR200 Iron with Auto...
How to use the kerf plate on black and decker cs108b
I am bit confused, what's a kerf plate? What blade are you using? I use blades from saw blade.com .
Dec 07, 2013 | Black & Decker Black Decker Firestorm 18...
Black and Decker Mega Mouse fails to oscilate.
try taking the base plates off and cleaning all the gunk out from around the bearings and area
Nov 29, 2012 | Black & Decker Black Decker MS700K Mega...
I purchased this coffee make in November '10 and the hot plate no longer heats up and the water does not pass through
Black and Decker is really good at helping with problems. Call them or email them and they will probably replace it
May 02, 2011 | Black & Decker 12-Cup Programmable...
How do i remove the blades from a black and decker 7696 planer
Solution of they-slide-out (losen any screw instead of removing same is always advised) is part of another answer on this site:
http://www.fixya.com/support/t6578544-looking_replacement_blades
the blades slide out after the top plate (3 screws) is removed, do NOT move the lower plates
BTW, my supplier of replacement belts can not obtain more belts..
Jun 17, 2010 | Black & Decker 2 pc. Planer Replacement...
How to replace ignitor on coleman furnac evcon model dgato70bdc i have a new ign and i need to know how much of the front of the furnace i need to remove or what part of the front to remove, the gas valve...
Hi some of these you do not have to remove the burner you just indo the hot surface ignitor its black with ceramic base ? if so you remove the metal cover over the burner and swap it out .
Feb 04, 2010 | Heating & Cooling
Are the thermal fuses near the coil or where the
The thermal fuse should be located near the coil. Usually just below the plate, but that all depends on the model.
I hope this helps! :)
Jan 17, 2010 | Black & Decker SpaceMaker ODC325 Coffee...
Black & Decker Lawn Hog 19" Mulcing Mower MM875 won't start
The rectifier is a flat plate with 4 posts that attach the electric wiring inside. You will need a flathead screwdriver to remove the four screws holding down the cover on your mower. on top where all the wires run (you will probably see one burned) There is a screw in the middle holding down the plate, you will need to replace the plate and resplice the wires that may be burned.
May 31, 2009 | Black & Decker 19" Electric Lawnhog...
Black and Decker Coffee Maker DE790B
The warming plate is controlled by the same thermal switch that cycles while brewing and they are mechanically in contact; it switches at about 150 degrees C.  Most later coffee makers have a time limitation as well and if they are so designed, will turn off completely after 30 minutes to 2 hours after the brewing is finished to reduce the chance of the machine failing. If you insist on having one that doesn't behave this way, you can buy a cheap one from a 'dollar store,' they don't have that feature and will continue to cycle until turned off.  Your B&D isn't malfunctioning, that is how it was designed.
Sep 05, 2008 | Black & Decker (050876530606)
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
