Question about Coffee Makers & Espresso Machines
Can you replace coil on a double burner hot plate by black and Decker
  • 30 Answers
SOURCE: Double coil spiral plates for cookers
what the heck are you refuring too?
Posted on Jan 30, 2008
SOURCE: how to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Posted on Nov 16, 2009
TheMobilian
  • 8220 Answers
SOURCE: burner will not get hot enough
When the burner arced out it probably also ruined the switch. Most switches on a standard electric range have 5 wires. 2 wires to the burner. 2 hot wires from power and a smaller wire which connects to the indicator light marked P. It is easy to test the switch Unplug the stove. Turn the suspect switch on wide open. Check for continuity between the 2 terminals going out to the burner marked H1 and H2
If you cannot get a reading then the switch has failed. Note: when replacing the switch usually on most stove the replacement will not be or look like the original HOWEVER it will still have L1 and L2 H1 and H2 and P but the terminals are not always in the same order. If you fail to correctly connect the new switch you will fry 2 switches when both get turned on. Ouch!
Posted on Aug 30, 2012
vinceisaac
  • 2432 Answers
SOURCE: black and decker steam iron #415 not hot enough - why
the contact switch for heat control not get good contact or dirty need to clean.
Posted on Nov 26, 2012
  • 50296 Answers
SOURCE: How Do I Clean underneath the coils of a Black & Decker Single Buffet Burner?
blown it out with compressed air .
Posted on Mar 30, 2015
How to use the kerf plate on black and decker cs108b
I am bit confused, what's a kerf plate? What blade are you using? I use blades from saw blade.com .
Dec 07, 2013 | Black & Decker Black Decker Firestorm 18...
Black and Decker Mega Mouse fails to oscilate.
try taking the base plates off and cleaning all the gunk out from around the bearings and area
Nov 29, 2012 | Black & Decker Black Decker MS700K Mega...
I purchased this coffee make in November '10 and the hot plate no longer heats up and the water does not pass through
Black and Decker is really good at helping with problems. Call them or email them and they will probably replace it
May 02, 2011 | Black & Decker 12-Cup Programmable...
Are the thermal fuses near the coil or where the
The thermal fuse should be located near the coil. Usually just below the plate, but that all depends on the model.
I hope this helps! :)
Jan 17, 2010 | Black & Decker SpaceMaker ODC325 Coffee...
How to replace line on the double sided spool for my grasshog
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker Lawn Hog 19" Mulcing Mower MM875 won't start
The rectifier is a flat plate with 4 posts that attach the electric wiring inside. You will need a flathead screwdriver to remove the four screws holding down the cover on your mower. on top where all the wires run (you will probably see one burned) There is a screw in the middle holding down the plate, you will need to replace the plate and resplice the wires that may be burned.
May 31, 2009 | Black & Decker 19" Electric Lawnhog...
Black and Decker Coffee Maker DE790B
The warming plate is controlled by the same thermal switch that cycles while brewing and they are mechanically in contact; it switches at about 150 degrees C.  Most later coffee makers have a time limitation as well and if they are so designed, will turn off completely after 30 minutes to 2 hours after the brewing is finished to reduce the chance of the machine failing. If you insist on having one that doesn't behave this way, you can buy a cheap one from a 'dollar store,' they don't have that feature and will continue to cycle until turned off.  Your B&D isn't malfunctioning, that is how it was designed.
Sep 05, 2008 | Black & Decker (050876530606)
Black & Decker TCM700 Coffee Maker problem
All coffe makers have a thermal cutoff fuse located on the bottom heating plate. It is usually in series with one of the leads to the actual heater. This should read "short" with an ohm meter. If it is "open" it needs replacement. They are rated in Degrees celsius, and are sometimes difficult to find. Black and Decker may be able to send you one.
Mar 11, 2006 | Black & Decker TCM700 Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
