When I turn on tv there is sound for a few seconds no picture then it shuts off and power button flashes.What could it be? Its a phillips projection tv model #60wbhdls2k6ra
  • 1153 Answers
SOURCE: tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Posted on Aug 25, 2007
SOURCE: No picture, hear sound, television will shut off after a few seconds.
Take out the bulb (back left hatch door) look to see if the element inside the bulb is broken or blackened - (replace bulb) if the bulb looks OK then it's the ballast that fires the bulb (service call).
Raf
Posted on Nov 30, 2007
SOURCE: Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
Even, I have the same problem...looking for a help on internet but not finding any...if you know...please post on this site.
Thanks,
Posted on Jan 13, 2008
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
SOURCE: LG Rear Projection Television Model RT-56NZ23RB - Fault
For my LG TV - LG RT-56NZ23RB, I replaced two STK 392-120 chips and it has fixed convergence problem now.
Posted on Jun 09, 2008
My 60 inch phillips tv, I turned it off the other night and now all i get when i turn it on is the power button flashing green. 6 quick flashes and then 1. I need my tv, plz help
Try a new Web search for your brand. Try looking for a Diagnostic trouble code of 6-1 and see if you can pull up parts of a Service manual using that search routine. Try Phillips trouble codes, Phillips Diagnostic Codes, or your model# in the search.
It sounds like it went into a default Diagnostic mode. If you have a Remote with extra functions it may get you into the Diagnostic menu.
Dec 20, 2011 | Televison & Video
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
TV turns itself off after a few seconds, no picture at all
Solutions?
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
did you ever get your problem fixed? i have the same problem and its frrustrating. i fyou can help me please email me at blake.shewmaker@fnbky.com.
Thanks.
Dec 26, 2007 | Philips 50P8341 50" Rear Projection...
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Televison & Video Logo
Top Televison & Video Experts
