Bliss light was working last night now flashing a single red dot no projection
  • 3130 Answers
SOURCE: video
How many times does the light flash?
Posted on Sep 29, 2007
SOURCE: Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Posted on Sep 11, 2008
  • 23 Answers
SOURCE: Sony SXRD Projection TV
This is a fan issue, most likely the large fan in the rear, lower left (from the back)...
Here's the fix, I promise, it's EASY........
Ok, I think I have the answer for the BIG FAN failure. I recently did a similar fix on the spindle of an xbox 360 and it is identical. Ok, this is an EXTREMELY EASY FIX...
Open the back of the tv, locate the large fan (on the lower left on the back of the set.) unscrew the screen and remove the fan.
Once the fan is removed, you will see the side with the model number and the other side is totally open.
On the open side, pull...
The fan will come off, into your hand, it is only held by magnets...
You will notice a spindle on the fan and the other side has the magnets and the hole where the spindle came from (this is the fan motor).
Clean both the spindle and the hole (motor) with a q-tip. The hole is smaller than the q-tip, but do the best you can to remove the old lubricant.
Get a bit of WD40 and lubricate the spindle and spray a touch in the hole.
Put them together, reconnect your fan, test it on startup and thank
Posted on Oct 01, 2008
SOURCE: No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Posted on May 18, 2009
I have the 50" SXRD TV and have expereienced many of the same problems as other owners. Sony replaced the optical block at no charge after the screen yellowing effect took place. Recently, I have the TV shut down with the flashing red light blinking in sequences of 4. After unplugging the TV for a few minutes, replugging it, and turning it back on, it worked again. However, this was not a pemanent solution as the problem returned. After reading several posts here, I turned the TV to look into the fans and voila, the one on the left was not spinning.
I took the back off of the TV (9 screws) and took apart the fan housing to vacuum everything. In addition, I vacummed everything else I could see. After putting it back together, the problem was solved. Save yourself a repair call. Get out a phillips screwdriver and a vacuum cleaner. Thanks to the posters on this site!!
Posted on Dec 28, 2009
A boat with a flashing red light at night what does it mean
The only requirement for a sea going vessel to use a light that is flashing red at all is for a wind in ground craft. (a pontoon enabled aircraft) that is flying close to, landing on or taking off from water.
Nov 06, 2016 | Televison & Video
I had a power surge last night and the video on my plasma is out. I have audio but no video??
I just replaced my bulb (XL2400) on my rear projection TV. I go to plug the bulb back into the TV and I get the error (red light flashing) that indicates that the bulb or the door is not securely in place. Is there a trick to getting the bulb back into the proper place. I messed around with this for over three hours last night.
Feb 19, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Washing machine wont stop it has been going from last night
turn off at wall and unplug .after a few minute's plug back in and try and reset machine by putting dial on one of the dots switch on the red light should flash 3 times and switch off .I this works try and put machine on again a spin only will do if the same problem returns you probable need a new pc board . cost about £55to 90pounds before fitting .
Feb 11, 2010 | Indesit W 123 Front Load Washer
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba model 53h71 will not turn on
I have the same problem - just happened last night. I found this posted on this sight. Does your problem sound the same?
Feb 03, 2009 | Toshiba 57H81 57" Rear Projection...
Single red light flashing
Needs 3 red light repair. You can contact us at
Jan 03, 2009 | Microsoft Xbox 360 Console
Sony wega 42inch
Power surge has damaged power supply, have serviced
Apr 22, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
5 Blinks, no picture
Power supply (start up) failure.
Mar 04, 2008 | Sony KP-51WS500 51" Rear Projection...
Sep 28, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
Top Televison & Video Experts
