Question about Video Game Consoles & Games
The fan has small red lights that come on even when the main light is turned off. What is causing this?
4 Suggested Answers
  • 23 Answers
SOURCE: 2 red lights
If your box never has been open you could send to MS for repair but since it is not the 3red rings error. They will charge you I think. You'll have to call and tell them your problem. If you want to fix the problem yourself you are going to have to open the box. Once you have it open you got to check the fan. Look and see if any wires came lose,disconnected or burnt up. If they seem ok check the clip attached to the motherboard. Just follow the wires on the fans. Pull the clip out push it back in. This is to make sure clip is in tight. You dont have to put the 360 back together to test the fans. Plug the power in and the video cable and boot it up. If it works great if not your going to have to buy replacement fans. http://www.talismoon.com/cgi-bin/version2/engine.pl?page=product-xbox360-whisperfan-red
Posted on Sep 27, 2007
dniro592006
  • 121 Answers
SOURCE: Main oven doesn't work
it sounds like your gas valve isnt opening
Posted on Jun 12, 2009
mr1967mejias
  • 637 Answers
SOURCE: Hitachi split air conditioner. I turn on the
Clean filters and reset.
Posted on Nov 23, 2014
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
Red light blinks and wont stay on when push power button
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it and you should hear a beep.
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and the red light will blink. When this happens, turn the main switch off and on then turn it on normally.
Tell me how this goes!!
May 05, 2011 | Sony Playstation 3 (PS3) Console
I have a Rheem Furance that has turned off. Just a few hours ago the main fan turned off. The Furnace doesnm't light even the draft fan does turn on and then the main fan blower motor turns on. I can hear...
You will need to reset the furnace by turning the power off to it. Then as the furnace tries to light, watch the LED for blinking. Hopefully it will give a code other than 1. Try checking the air filter for blockage, make sure all hoses are free of moisture and any drains are not blocked. Check the air intake and exhaust pipe for sags where water could block it.
The sequence of operation is this:
Thermostat calls for heat, the LED may blink telling you it registers the call. The inducer (exhaust) blower starts closing contacts in the pressure switch (small disc shaped thing), the igniter glows orange (seen thru a small window high up on furnace front), gas valve opens allowing main burner to light, flame travels to all other burners, flame rod senses flame within a few seconds and keeps gas on. Room air blower starts within 90 seconds.
Any deviation or delay in this sequence and it goes into lock-out.
Jan 22, 2011 | Heating & Cooling
I have a ceiling fan with lights, last night the fan was turned on for the first time since summer, the remote is over the light switch. The remote to turn on the lights is used normally. Since turning...
There is a small relay in the ceiling fan causing this noise, try turning off all power to the ceiling fan and allow it to set for a couple of minutes. Turn it back on and see if it goes away. If it does great. if not, it may not be worth the repair cost but it can be fix by an appliance tech.
Dec 22, 2010 | Hunter Heating & Cooling
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
My ps3 turns off by its self and goes to a flashing red light
Look at the light carefully when it is flashing. The yellow light error is easy to mistake for a red light error. If it is indeed just a red flashing light than this is usually an overheating issue. There are 3 main causes for this: 1. Fan has burned out 2. Power Supply has burned out 3. The motherboard has a short circuit
The PS3 will need to be professionally repaired to permanently fix the problem. GATpro Repairs will take care of that error for $79 with free shipping!
Jun 11, 2010 | Sony Playstation 3 (PS3) Console
Heat was working until 2 days ago. When i turn on heat nothing happens not even the fan turns on. I have a bryant cant find the model type. There is aslo a blinking red light
Hello
First check that the main circut breaker is not blown.
Next be sure you have gas or fuel oil going to the heater.
On some units there is a reset button located in the furnace control panel or a small low voltage fuse could be blown.
If a reset button is there push it in.Check your documentation as to what would cause this to happen.
Jan 22, 2010 | Honeywell Programmable Thermostat Heater
Jun 12, 2009 | Ovens
2 red rings or lights on my xbox 360 after i tried fixing RROD
ok u need to leave it on for about 30 min. (u only need power cord in) when ur done with that, put it together and it should work for me.
Mar 12, 2009 | Microsoft Xbox 360 Console
Kdfe55a20
You are correct that a 4 flash is a fan problem. It could be that one or more of the fans is not turning, I have also seen a failure of the fan rotation sensor that tells the TV that fans are turning cause this problem. Lastly, in rare cases a power supply problem can cause a 4x failure, when the supply for the fans fails.
Jun 17, 2008 | Sony KDF-E55A20 55 in. LCD Television
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
