How to fix green vertical lines on the left side of my 32" flat screen tv
    Master:
  • 708 Answers
If those are real fine lines all the way from top to bottom, that is a section that has failed. I don't believe there is a way to repair it. Robot Check
Posted on Dec 15, 2016
    Master:
  • 277 Answers
Posted on Dec 14, 2016
circuitworld
  • 335 Answers
SOURCE: green line down left side and geen snow
Horizontal or vertical bars on the screen could be from an ac line interference, adjacent magnetic field, bad input wire connections.....especially HDMI connector cables. A bad HDMI cable causes all kinds of unwanted picture interference. Check the conditon of all connection wires for proper fit and function. Keep in mind the method in which you connect your tv will result how the tv performs. As well this line problem could be a circuit issue too, requiring a technician to look at it.
Posted on Jan 04, 2009
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
SOURCE: One green vertical line in HDTV Vizio 42
Try changing the H/V position in the TV Set Up menu. You can adjust the horizontal and vertical position of the screen and move it enough that the green line disappears from the screen.
Posted on Feb 16, 2009
  • 105 Answers
SOURCE: Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Posted on May 21, 2009
SOURCE: Vertical black line on the screen of my 42" Magnavox flat panel lcd tv
I wish I could post a solution, but I don't have one. I too have a Magnavox. About 6 months ago, once every 2 weeks or so, the screen would just go black- all but an inch or two on either side. Now, it seems like it's a weekly thing, sometimes every hour or two. As of tonight, it has happened twice in a matter of thirty minutes. It usually repairs itself if I turn it on and then off again but that's just not working anymore. If anyone has a solution, let me know.
Posted on Dec 20, 2009
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
Mar 17, 2014 | Televison & Video
Vizio 32 inch thin black vertical line on left side of screen
it is very likly you have problem with the buffer boards, sometime help to unplug conector and reconect, also check the smd fuse located on one of the boards since there are 2 buffer E&F.
Jan 09, 2013 | Vizio 32" Lcd Hdtv E320VA Hdmi Hd Tv Flat...
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Oct 14, 2009 | Televison & Video
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Green line down left side and geen snow
Jul 23, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Green vertical lines on panasonic viera screen
I have two vertical very thin green lines on TV how do I fix
Jun 26, 2008 | Televison & Video
May 18, 2008 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
