We have a interthem 2460 furnace and we have it hooked up to the power but it is not putting out heat just warm air, what could be wrong?
  • Heating & Co... Master
  • 2,557 Answers
Is the thermostat calling for heat?
Posted on Dec 14, 2016
We have a interthem 2460 a furace and we need to know where to find a wiring diagram to show us how to connect it to the electric
If there is not a wiring diagram pasted inside the furnace somewhere, request it directly from Intertherm. Be sure to specify model 2460.
Dec 09, 2016 | Heating & Cooling
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Nov 11, 2014 | Heating & Cooling
Furnace problem
SHUT THE POWER OFF TO THE FURNACE, REMOVE THE THERMOSTAT FROM THE THERMOSTAT SUB BASE TAKE THE WIRE THAT IS ON THE R TERMINAL AND THE WIRE THAT IS ON THE W TERMINAL AND CONNECT THEM. TURN THE POWER BACK ON. IF THE FURNACE COMES ON AND WORKS FINE THEN ITS IN THE THERMOSTAT.
May 30, 2017 | Heating & Cooling
On my therostat it show and talks about the R wire and the Rc wire. What is the differet?
If you would have a two transformer system..... The power wire from the furnace transformer would hook up on R and the power wire from the Air Conditioner transformer would hook up to Rc....
BUT most systems now only have one transformer...... So if you are using this thermostat you will need to put a jumper wire from R to Rc. So the Air Conditioner will work. Furnace is the source of the transformer. R/Rc,W,Y, C, on the Thermostat will Hook up to R,W, Y,C on the furnace and Two wire from the Air Conditioner would hook up on Y and C on the furnace.....Good Luck.
Apr 02, 2011 | Heating & Cooling
Outside ac unit operates but no blower. Fan "on" does not operate from thermostat. However "heat" works fine furnace and blower. ???
Go to furnace and shut off power, remove blower door compartment. Inside you will find a control board where thermostat wires are connected. Should look something like this:
R-Red Wire= Power
G-Green Wire= Fan
W-White Wire=Heat
Y=Yellow or Blue Wire=Cooling.
It sounds like you have a bad motor speed. So try this:
With Power Still Off, on the same control board there is a terminal usually marked Cool and Heat. There should also be a couple of terminals that are named park. The wires hooked to these are the fan wires..
Exchange the Heat and Cool wires on the terminal board. Put everything back together and try cooling again, if the fan comes on
then you have a burnt out motor speed. Go back to furnace and change
the heat and cool wires around, next if Cooling had the black wire hooked to it, put yellow or blue on Cooling and black to park.
Note: The reason why you put the blower door back on is because it
has a door switch that if not properly seated, you wont be able to power
up anything
Jun 22, 2010 | Heating & Cooling
My furance is running and will not turn off the air-condition was on but now will not run but the furnace is still running but but does not turn off at themastatic can you tell me what to do for this...
I suspect the sequencer is stuck. However, you may have a thermostat problem or a short in the 24V. If it is a heat pump then likely the reversing valve is not kicking in. There can be numerous causes for this and you should probably call a pro in for this one. Diagnosis is not such a simple thing.
Jun 29, 2010 | Goodman CLQ36AR49 Air Conditioner
My heater is not heating anymore, what's the
Sounds like an ole electric furnace with heating elements not kicking in or burnt wire to the controllers..
Dec 17, 2009 | Heating & Cooling
Aprilaire
Commonly outdoor wood boilers use a hot water coil mounted in the ductwork above your furnace. In this application the Ruud furnace is still using its blower assembly to circulate the warm air from the boiler to your home. If this is the case. Have your heating guy install a #50 relay on the furnaces blower motor to activate your much needed humidifier. If this is not the case and your Ruud furnace is totally independent of the boiler. Still install the #50 relay in the furnace and manualy activate the fan only feature on your thermostat.
Good luck
HVAC Teacher
Feb 21, 2009 | Aprilaire 600 Humidifier
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
