We have a airbath but the led light gone off and does not work
    Master:
  • 286 Answers
I am not sure of your question, but your airbath should be plugged into a GFCI receptacle. Unplug it and see if you can reset the receptacle with the little reset switch on it. If you can reset it, then plug the airbath back in. If it trips the receptacle again you have an electrical problem with the airbath, It is possible that instead of a GFCI receptacle, you have a GFCI breaker in the electric panel. Same thing, reset it in the panel.
Posted on Dec 14, 2016
My airbath tub when turned on is knocking all electric off in house what can be problem?
Sounds like you may have a serious electrical short with the motor on your air tub. Recommend you stop using the tub and call a licensed electrician ASAP.
Good luck.
May 09, 2016 | Home
When i turn on airbath it cuts all electric off
What type of car or truck is this?
May 09, 2016 | Cars & Trucks
Led tv no picture
Sounds like fluorescent tube has gone, but you say this is LED? Newer tvs are LED. What you have, may be LCD, in which fluorescent tubes were used. You have no recourse.
Feb 12, 2014 | Televison & Video
My 2007 gsxr 600 braklight keeps burning up the leds and the brake light doesnt work but the running light and turn signals work fine
u need a resistor something to reduce the power ur board in the light shuld have one built in it may have gone leds run on typicaly around 3v ur bike produces between 12 and 14 v its the same as when u fit led indicators u need to restrict that power down
im asumeing the brake light dont work because the leds are dead not because there is no power to them
best advice i can give is u need a in line resistor similar to the ones used on led indicators they take away some of the power and release it as heat energy with the decresed current the leds shuld be almost just as bright and last a lot longer hope this helps
Oct 30, 2012 | Suzuki Motorcycles
Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Apr 03, 2010 | Samsung Televison & Video
Mixer volume LED's do not work
a circuit controls the LED meter. i dont think the LEDs are faulty. the LEDs are connected to this circuit (IC). changing the LEDs wont work.
Mar 14, 2010 | Audio Players & Recorders
All lights work, except the brake /tail lights,the L.E.D. brake light on top works
The third break lights are LED and the circuit board may have gone bad or the solder may have gone bad. The circuit board is built in the third brake light and is a seal unit. You may have to replace the unit, there is a relay for the third brake light and that is located on the glove box behind the panel that say's relays. There are three relays in there, the center is for the fuel pump and the two out side are for the A/C and third brake light. Just swap them around and see if the brake lights come on. Good luck and keep me posted.
Jun 25, 2009 | 2001 Chevrolet Blazer
Display problem
If ur keypad lights r workin then there could be two problems
1. Display LED'S are gone
2. Display LED's Driver IC is faulty
In both cases u will have to show it to a technician
Feb 13, 2008 | Sony Ericsson W700i Cellular Phone
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
