Question about Garden
Had trouble starting the snowblower but when it finally started...it went straight to about 3,000 rpms and I thought it was going blow up. I pushed the choke in and it went faster.
  • Garden Master
  • 2,536 Answers
Sounds like the springs on the carb have either come off or broken or got caught on something. Don't run this way or it will ruin it.
Posted on Jan 06, 2017
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Cat or fuel pump problem?
have somebody rev the engine then go to the tailpipe and check if you have strong air comming out. if you have then its not the cat. if its the pump big chance is you cant even start the engine. check the air filter first then the fuel filter. i think youll find the problem there
May 29, 2009 | 1992 Toyota 4Runner
I have a 1987 ford-150 straight 6 engine in it, only has 71,000 miles on it and recently i had a problem with the truck shutting down and if you gave it a few minutes it would fire back up so i had the...
You probably need a tune up or timing might have been changed which would alter the rpms. Replacing the module can erquire moving the distridutor and it may not have been returned to the same position. I have experienced same problem.
Jan 04, 2009 | 1999 Dodge Ram
No Heat in 99 Taurus
Just finished fixing my daughters 1999 taurus heat. It would blow warm only when running down the road. At idle it blew cold. I started with replacing thermostat, and water pump because they are the easier fix. Still did not help. Then I replaced the heater core. A daunting job but not that hard to move the dash slighly out of the way to replace. There is a good write up at tarusclub.com. After that, heat was better but at idle, it would still blow cool sometimes. Researched and found answer. Park car on the steepest hill you can find with front of car up. Start car and take off reservoir cap. Let car warm up and keep rpms about 1500. After a while the fluid will come running out of the car and all over the place but it will bring air bubbles with it. Reduce rpm, add more fluid and repeat about 3 times. It will make a mess but after that, the heater works perfectly. We get heat long before the temp gage indicates any and it never blows cold unless you lower the temp.
Nov 21, 2008 | 1999 Ford Taurus
STARTING AND DYING
I would without a doubt check the fue pressure on this vehicle. The schrader valve is located on the p.side of the fuel rail. If low, check the fuel filter. For the price I personally would change the filter just for the piece of mind. On the side of that the fuel was going into the engine, blow air through onto a clean rag to see what debris was in the filter.
Aug 11, 2008 | 1996 Pontiac Sunfire
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
