Question about Bissell Vacuums
Bisseell petwash powerbrush how to get the return dirty water container clean.
Bissell petwash power brush not a coffee maker
  • Bissell Master
  • 16,973 Answers
This has always been an issue with this make of cleaner. You can rinse it out and then leave the lid off to dry and that eliminates odors from mold and bacteria. IF you really want to clean it you need to get small brushes like a tooth brush etc and scrub it out.
Posted on Dec 13, 2016
Testimonial: "I have tried everything you mention-nothing works. There has get to be a toothbrush made that can go around corners and through small holes. The design is ridiculous"
  • 1 more comment
  • Brad Brown Dec 13, 2016
    I agree with your statements. You may want to try pipe cleaners.
  • Angela Pugh
    Angela Pugh Dec 14, 2016
    Pipe cleaners do get some parts so does flower wire. Husband suggests I am too fussy, and to hide it in the cupboard when not in use.
  • Brad Brown Dec 14, 2016
My bissell proheat will not suction dirty water. What should i do?
take it apart and clean the pump, its clogged for sure.good luck
Jul 31, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Wont spray the cleaner n water out
check the dial setting. - presoak, off, cleaner, rinse
is cleaner bottle correctly inserted?
is clean water resevoir empty?
is dirty water resevoir full?
these items will prohibit the water/cleaner from coming out.
Mar 28, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Power wash /powerbrush sprays the carpet ok ,but when empty doesn't fill up with any dirty water from the carpet .Is there anything I am not doing correctly
It sounds like the suction isn't working right. Check the dirt tank to make sure it is on correct and check the red plastic filter on the dirt tank to make sure that it isn't clogged.
Dec 02, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Mar 18, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I need directions for using the Bissell Little Green.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723971
Generic problem for all Vacuums
Posted by jkcanger on Jun 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. If the instruction did not come with the Bissell Little Green Machine then I would contact the Bissell Factory that I will provide for you listed 2 the bottom of the answer,
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 30, 2008 | Kenmore Progressive Bagless Upright with...
I am wondering how I can clean the inside of my bissell spotlifter powerbrush hand held cleaner? I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=49876&thid=506980
Posted by carriespets on Apr 12, 2008
I am wondering how I can clean the inside of my Bissell Spotlifter Powerbrush hand held cleaner. I want to clean the part where you suction up - it is full of gunk and hair and I can't figure out if it comes apart or not so I can clean it. Can you help?
Normally on the Bissell Spotlifter Powerbrush the item will comes apart from the sides into 2 halves and then you can either clean out or blow out the inside of the
Bissell Spotlifter Powerbrush, also you can take a wire coat hanger and straighten it out and bend a hook @ the end of the wire hanger and you can use the hook to pull out the clog or whatever is blocking the opening and you can also use a blower or an old tooth brush to clean the motor or to brush it off.
Always, check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 12, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Vacuums Logo
32 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
