Question about Saws
Blade broke in saw
Need to remove blade
  • Brad Brown Dec 13, 2016
    Hi lillie harris, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? what saw make model
  • 35 Answers
SOURCE: blade stuck in the chuck
If you have the lock released and can't get it out try pointing it towards the ground and running it. the piece should fall out unles it is still locked in
Posted on Dec 01, 2008
rowdy45176
  • 2176 Answers
SOURCE: Reciprocating saw-snapped blade-cannot be removed
What I would try is to spray some WD40 on the pin first and then see if you can find a small screwdriver or punch and try pushing the pin in further to release the broken blade. It doesn't sound as though it is anything major, maybe a burr on the side of the pin or possibly rust or debris. DON"T hit the pin because you might damage it or push it in and never get it back out. Looked at a diagram and it appears that they used roll pins to hold the clamp in place so it might be that one is cracked or mushroomed and you might have to drive them out. I suggest that you go to Searspartsdirect.com and type in your model number to look at the same diagram.
Posted on May 26, 2009
VtToolMan
  • 704 Answers
SOURCE: Scroll saw Model 572.247200 need manual or at
According to the Sears web site, your sroll saw uses the #8030 blades, which have been replaced with #5088029. These are available from any Sears store or online at the following link, see item #31 or 31A, priced at $4.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=+572.247200+&productCategoryId=0744440&brandId=0247&modelName=CRAFTSMAN-15-INCH-MOTORIZED-SCROLL-SAW%2FSANDER&diagramPageId=00001&documentId=00033222&pop=flush
It would appear that the owners manual for your scroll saw has been discontinued and is no longer available (Sears #405015) But the line drawing and parts list may be of some value to you, should you need to do any repairs later on.
I hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
  • 57 Answers
SOURCE: blade stuck in reciprocating saw
The pin is probably stuck in the blade. This happens from time to time after they get dirty. Take some WD-40 or some other type of penetrating oil and spray a little in the blade holder while working the release lever. It will probably free right up.
Posted on Apr 24, 2010
  • 2006 Answers
SOURCE: How do I remove a broken blade on a reciprocating
Sometimes if you take the set screw completely out and then use a flat blade small screw driver to wege open the throat you can use a dental pick to get it out. Spray it first with wd40.
Hope you weren't using those cheap blades from harbor freight - that is how I learned that trick - bought the dental picks from harbor freight.
Posted on Jun 20, 2011
Blade broke off inside
how does it fasten in . an allen screw or is it a quick release coupler .if set screw that it out then run the saw maybe the vibration will jiggle it out .
Dec 12, 2015 | Saws
Remove blade from master force saws all
  • 1. Disconnect the saw from the power supply.
  • 2. Open the blade-clamp release lever.
  • 3. Insert the saw blade into the blade clamp as far as it will go, and release the blade-clamp release lever to lock the blade in position.
  • 4. To remove the blade, open the blade clamp release lever and pull the blade from the clamp
Blade cannot be removed Saw dust in the clamp slot
Clean the clamp slot with brush
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=masterforce+saws+manual
Dec 09, 2015 | Saws
How do I get a broken blade out of Dewalt DC330?
Do the same procedure on how you installed the blade.
Sep 14, 2014 | Dewalt 18v 18 Volt Cordless Xrp Jig Saw...
I hava a 7 1/4 circular saw model # 5250. The blade broke off and we can't get the bolt loosened enough to replace the blade. Any ideas on how to get bolt off?
If you have no way to prevent the motor from turning when you try to remove the blade bolt, you are going to have to immobilize the armature to get it off. Remove the cap on the motor housing so you can remove or relieve the spring pressure on the brushes. Then remove the motor housing with the field, leaving the armature attached to the blade guard/transmission assembly. Now you can safely hold the armature while turning the blade bolt.
Oct 06, 2012 | Skil 5250 Circular Saws
Want a operating manual for saw zall 6523-21....blade broke in saw....want to know how to get broked blade out of saw
I believe that one has the quick release chuck, right? The one where you rotate the outer ring to release the blade? I would turn it to the release position with it pointing towards the floor and tap on the side of the chuck with a screwdriver handle or small hammer. (you may need help with this due to lack of extra hands, and of course, unplug it first.) Good Luck.
Mar 07, 2010 | Hand Tools
My Craftsman 8 1/4 Radial Arm saw
tighten retaining bolt if still spins remove bolt and add a washer to the out side of blade between the bolt head and retaining washer and retighten
Jan 29, 2010 | Craftsman Saws
I am trying to replace the blade in my scroll saw because the other blade broke and I can't seem to figure it out. Any suggestions?
Manking an assumption that yours looks like this one below?
If so, you'll need to flip up the yellow catch to release the jig blade. Sometimes they get a bit stiff, so wearing gloves try and waggle the blade free. There is normally a tensioner at the back that guides the jig blade (like a roller) that can also be loostened off to get the blade out
Install is reverse of removal
If this helps, pls leave feedback, if not let me know and I'll try and help some more!
Jan 27, 2010 | Ryobi Saws
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
Putting on a saw blade
Well M8:) try to to unloose it backwards, It dosent loose as usal, you need to posh the otherway. Nornaly you loose things from right to left, this one (and other items that cut) you loos from left to right.
Good luck to you
Dec 18, 2008 | Bosch 12" Compound Miter Saw 3912
Saws Logo
88 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
