Question about Health & Beauty
My Jazzy goes on but does not move. I noticed an answer was to check the circuit breaker on the chair. Can you tell me where that is located?
  • 38 Answers
SOURCE: We have a Jazzy 1113
The battery of the chair is dead. It will say its charged but then when you take it off it will die.
You have to replace the battery.
I had the same exact problem with my father.
Posted on Dec 30, 2008
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
SOURCE: Fault codes jazzy 600 power chair
8 lights flashing how can i fix it?
Posted on Sep 20, 2011
  • 5 Answers
SOURCE: Jazzy 1121 power chair won't go
I find a lot of the controller Problems are caused by the cable running from the joy stick down to the controller gets caught on something or rubbed against something and one or more tiny wires inside are broken ... If I find a spot on the cable that is worn through, that's where I start .. Open up the insulation and check the tiny wires .. fine the broken one and repair it .. usually that solves the problem and saves you a couple hundred for the cable
Posted on Oct 08, 2011
SOURCE: Circuit breaker location
I have 2004 1/2 700 sportsman that had the same problem. The circuit breaker is in front of the handle bar, under the plastic cover. you will have to remove front luggage rack if you have one. Look at the wire harness and locate a plastic sealed rectangular holder about 3 inches long. It is automaticly reset when it cools down.
I kept having power loss that could be restored by tapping on the plastic holder.
I cut it open and found the connections corroded on the 20 amp circuit breaker inside. Seal plastic up if you cut it open to keep it from shorting out and to keep moisture out.
Posted on Mar 18, 2012
My chair will not change speeds. Very slow, No flashing lights
That is possible. Check the power circuit from the battery and see if there is any loose connections or resistance in the circuit via the voltage drop method. Here are some links that may help:
Jazzy 1113 ATS Parts
Redirect Notice
Redirect Notice
Mar 03, 2015 | Pride Jazzy 1113 Power Chair
Jazzy 1113 ats fully charged will not move
Check the controller connections and the circuit breaker.
Oct 23, 2013 | Pride Jazzy 1113 Power Chair
Jazzy 614HD goes into lockout. We can get it out of lockout but goes back into lockout at any movement of the chair........
Make sure any seating system is completely down and in DRIVE position. When chair is unlocked, wait 5 seconds, shut chair off, wait 5 seconds, turn chair back on. Each time you turn the chair on you need to wait 5 seconds for the POST to complete before moving the joystick.
Oct 14, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
I have a Jazzy 1103 Ultra and the lights are all on like it should be but the chair will not move. I am in Mississippi visiting my daughter and would love someone to help me. Thanks!
It could be a few things.
It might be on freewheel. To solve this: 1. Turn the chair off. 2. Locate the freewheel lever just behind the drive wheel, and on top of the motor. 3. Push the lever inward to engage the motors. 4. Repeat steps 1 and 2 for the other side. 5. Turn the chair on and see if it works .
If not, it the circuit breaker might need to be reset because of heavy strain on the motors and batteries. To solve this: 1. Turn the chair off. 2. Find the circuit breaker on the front of the case, off to the right side (you will see a hole in the case) 3. Press the circuit breaker button. 4. Turn the chair on and see if it works.
if not, the battery may need to be disconnected and reconnected To do this 1. Turn the chair off 2. Release the friction lock lever under the seat. 3. Remove the seat. 4. Release the rear shroud fastener and the yellow fastener under the front shroud. 5. Remove the shroud. 6. Disconnect and reconnect the battery connector (the big plug) 7. Replace the shroud and seat. 8. Turn the chair on and see if it works.
If not, contact your provider.
Feb 23, 2011 | Pride Jazzy 1103 Ultra Indoor Power...
I have changed out the batteries and hand control on my Jazzy 1103 Ultra.but now the circuit breaker keeps tripping. Dee
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
Jan 31, 2011 | Pride Jazzy 1103 Ultra Standard Power...
My jazzy chair did charge up when we plugged it in last night. Is there something else wwe can do to get it to charge up?
Things I would check are ... Power at the outlet? Is the charger ON? Is there a fuse or circuit breaker involved? Are you certain it was plugged in (charger to charge port)? Have you noticed any deterioration in its operation recently?
Nov 01, 2009 | Pride Jazzy Select 6 Indoor Power...
I hit a curb accidently and now the chair is dead
there is a inline fuseable link located on the posative battery cable it can get loose and still look like there is nothing wrong,that was what was wrong on my chair. I was very lucky to find it(i found it by sheer chance, I was leaning against it and noticed the light goin on and off,Holy light display batman!) just my lucky day I I say Check ALL FUSES!!!even ones hiden under tape or shrink wrap. Hey Good Luck to all and keep the paint up and the rubber down....zoooooom....
J Olaf
Oct 15, 2009 | Pride Mobility Products Jazzy Select 14 XL...
This is a Jazzy powerchair.
What model Jazzy is it? A soft idle??? Like a purr or is it a grrr? Purr is okay, gurr, bad.
During a thunderstorm, any and all electronic equipment should be either unplugged, or put onto a power strip that has a replacement gurantee for any damage as a result of a storm, etc.
Yes, you can take a shot through the charger and it can whach out your controller, and cost about 1,200 bucks to fix. If you are lucky, it'll trip the circuit breaker on the chair.
Jul 07, 2009 | Pride Jazzy Select 6 Indoor Power...
Mar 31, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Health & Beauty Logo
63 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
