Question about Apple Computers & Internet
How to fix a computer motherboard
Hp Motherboard, Dell Motherboard, Apple MacPro Motherboard
  • Apple Master
  • 17,417 Answers
Not normally repairable. Buy a new one, used one or upgrade the computer.
Posted on Dec 13, 2016
How do I change a motherboard on my hp pavilion elite model m9650f?
Some HP and Dell desktop computers motherboards and cases are not the standard design and so cannot be modified by changing the motherboard for a non-HP one as it wont fit.
If you are going to change the motherboard on such a machine for a retail bought board then you may as well replace the case at the same time and re-build a new computer from the HP parts.
Changing your motherboard will in effect 'de-brand' your computer anyway as all that makes it HP or whatever in terms of hardware is the BIOS software on the motherboard.
Please rate if this helped you.
Jun 04, 2014 | HP Pavilion M9040N Elite Desktop PC
Hi Q about ATI Radeon HD 5770 [ for Apple MacPro] .. will it work on asus motherboard, / power sup, voltige and more , thx
I don't believe so. The programming in that card would be for a Mac and not work with none Mac systems. In normal cases if the card will fit the slot you could expect it to work but in this case if it specifically says it is for a Mac it will only work in a Mac computer.
Jun 02, 2011 | ATI RADEON HD 5770 Graphics Upgrade Kit...
Hi i have a macpro 13" not turn on ,the pwr adapter light its dim, i replace the adapter and continue not turn on . its not a new mac and was working few hour ago
If the power supply is dim it indicates a motherboard problem and is loading the charger down. The only option is to have a computer tech who is familiar with Apple Notebooks to check it out with an estimate.
Jan 07, 2011 | Apple MacBook Pro Laptop Computer with...
MacPro 8-core fails to startup. No power.
If nothing is happening, then you probably have a bad power supply or you have bad connections between your power supply and motherboard. You can take the cover off and make sure that everything is plugged in well. Make sure to touch the side of the case to dispel all static electricity before you touch any of the components. If the machine fans turn on and then it refuses to boot, you might have a bad hard drive or a motherboard issue. If you hear any beeps at startup, you can look those up online because every beep configuration is a clue to something wrong with the machine.
Jul 19, 2010 | Apple MacPro 8 Core 2.66GHz Quad Core...
Scanning problems. Could not scan into old Dell Laptop anymore. (Motherboard bad on Dell). Now, new computer Apple, and tried to scan. Says it is scanning into HP Photo program, which is not on this new...
Try these. 1 in applications find image capture, make sure printer is conected and on, launch image capture and see if it finds the scanner. 2 go to the HP website and see if there is software to download.
Mar 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
Need to replace the motherboard on my computer and need to know what motherboard to order
what kind of computer do you have, who made it, if it hp, or dell or a factory made like them, you need their part number, go their web site. If not, go to this link and install then run belarc advisor, it will tell you make and model of your motherboard
http://www.belarc.com/free_download.html
Jun 20, 2009 | Dell Computers & Internet
Unlocking iwork 09 family version
alot of times this means your connection between your motherboard and the charging unit is damaged. it is not making contact. Only the dell or a repair shop can replace the motherboard or fix the connection on the motherboard
May 09, 2009 | Apple iWork 09 Family Pack Full Version...
Hello I got a problem with MacPro 3.0. I have changed motherboard for new one, put every cables and everything in the place. The only thing that's changed is motherboard. When I connect Pro on Apple...
How do you know the graphic card is working if you can't get a picture?
Sorry to be basic about this, but you really need to go back and check your connections again.
Do you have another Mac? You can boot the Mac Pro into target disk mode, then boot the other Mac off its disk using a FireWire cable. Then you can set up Apple Remote Management and enable VNC logins on that machine; then shut everything down and reboot the Mac Pro of its own drive. From the other Mac, use Chicken of the VNC to remotely view the Mac Pro's "screen" (I assume existence of an ethernet network here). Now you can run any tool on that Mac from the other Mac -- visit the Displays panel, look at System Profiler, etc., just as you would if the hardware display were working.
May 04, 2009 | Intel Mac Pro Tower Desktop
Dell Motherboard Dell Part # RG156
dell make it hard for the cosumer to repair there computer because all of the extras they install i would first download a newer vga driver for vista and a accerlrator that should fix the problem
Aug 21, 2007 | Dell (S423) for Dimension 8100 (3F546)...
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
