1985 Noma NE-14 electric shovel, used for 1st time last wk. Was running great , next day i used it again and turned the key and won't run. Can't find any help anywhere on internet.
I've changed the extension cord, the outlet I was plugged into, I've turned the key and I am lost as to why this machine just stopped running. I even warmed it up indoors overnight. Need help before I take it apart
    Top Expert:
  • Washing Mach... Master
  • 48,384 Answers
As it is electric it is not a job for diy
could be deteriorated insulation, vermin infestation(ants) or nay number of faults that when disturbed will cause a shock to a person not experienced in electrics
take it to an appliance repair shop for a proper diagnosis and test
Posted on Dec 13, 2016
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
Well run for some time then turn off while driving I wiil pull over then it will start again same thing again next day.
car is 20y--somethin gettn hot in the electrics-wiring and components wear and develop resistence--bring it to a specialist for testing--1st chec distributer cap for inside wear urself--also cud be ignition switch or fuel issues
Jun 14, 2012 | 1992 Chevrolet Lumina
2002 kia spectra automatic - sometimes won't start when key is turned, all electrical systems go on but nothing to the starter. After several tries it miraculously starts but sometimes can set for a...
check your battery sometimes it will have enough for lights put not kick in starter then check alternator take to auto zone when running the will test free
Oct 17, 2011 | 2002 Kia Spectra
Car doesn't run great but it runs. I turn it off and it won't start for a little while. Then it will start again
Make sure your coolant level is full first. Next, change your coolant sensor. It is located near the thermostat housing. When this condition happens 9 out of 10 times it's the coolant sensor malfunction or low coolant level! Good luck!
May 24, 2011 | 1985 Dodge Diplomat
1985 vette starts and runs great untill you shut it off and try to start it again...i have to wait 15 - 20 minutes before it will start again, whats this all about???
when it won't start do u hear the hum of the in tank electric fuel pump when the key is tured to run, it will only hum for 1 sencond, so turning it back off and to run repeated times helps to hear the pump.
May 20, 2010 | 1985 Chevrolet Corvette
27kmiles. Runs great. Engine cuts out.
i would lean towards replacing the ignition switch.
Apr 09, 2010 | 1999 Porsche Boxster
Lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Dec 01, 2008 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
F150 ignition (won't Start)
If it turns over but just won't fire and the timing sounds fine when it does run you might consider your ignition switch.  Does it sound like it wants to fire but only just when you let go of the key?
Aug 06, 2008 | 1985 Ford F150
Washing Machines Logo
Top Washing Machines Experts
