Question about Oreck Vacuums
Is there a reset button on the upright oreck xl classic?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 19 Answers
No there is no reset switch. If you have no power, make sure wires are connected to switch inside handle.
Posted on Mar 13, 2017
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 5 Answers
SOURCE: My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Posted on Oct 15, 2008
  • 4 Answers
SOURCE: formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Posted on Apr 24, 2009
  • 121 Answers
SOURCE: Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Posted on Oct 16, 2009
Testimonial: "Quick answer and the same thing I found out after I posted from an Oreck repair site. Thanks."
The roller brush on my Oreck XL Classic has only center bristles. Both sides have been worn down to nothing. It is hard to push.Why are the bristles wearing down?
Sounds as if the wheels are collapsed on one side and the brush is harder in contact on one side. In correct alignment the brush should just kiss the top of the carpet causing the bristles to flex a little.
Oreck will fix it for you under warranty;
http://www.oreck.com/oreck-xl-classic-limited-edition-bagged-vacuum/UK2200.html
The XL® Classic Limited Edition is confidently by Oreck®'s warranty and 9-point free service tune-up inspection plan to ensure optimal performance for years to come.
Returns information is here
Returns
Oct 30, 2016 | Oreck Vacuums
How do i reset my oreck xl edge upright vacuum
check the Oreck web site or utube for solution. the manual maybe available on Oreck web site.
Dec 16, 2014 | Oreck XL Edge Upright Vacuum
I have to replace a motor on an xl classic. The bad motor is out and i do not know exactly where the wires connect on the new one. I need a wiring diagram.
Hi, it's Jeremy from Crucial Vacuum.
Below you will find a link for many different models of the Oreck XL Classic Bagged Upright Vacuum. I hope you find the link useful.
http://www.oreck.com/PUG/76054-01-REV-A-U2251-CLASSIC.pdf
If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 22, 2014 | Oreck XL® Classic Bagged Upright Vacuum
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Removing and cleaning Oreck XL outer bag
how do i get the outher bag off of my oreck xl
Jan 16, 2012 | Oreck XL Ultra Bagged Upright Vacuum
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Classic User's Manual
The manual for the Oreck XL Classic Upright Vacuum U2251 is located on the site below.
Mar 03, 2011 | Vacuums
Oreck XL upright - has a 2 speed switch. Now only works in high speed not low speed. Will a new switch correct or is it the motor
Your vacuum is fine. The switch can either run at full speed or half speed. You are running at full speed, you need a new 2 speed switch. You can pick them up at an Oreck Store for $29 or around $15 on eBay
Jan 17, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Classic
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=703827
Oreck XL Classic
posted by balis on Jun 24, 2008
The belt is on properly, however the brush will spin, then stop.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Classic. It sounds like the belt may be stretched out and my needs replacing. The average belt change is every 4 to 6 months and to store the extra belts in a Ziploc bag in the refrigerator. Also check the brushroll, the gray bearing ends with say on either side the words NEW or OLD and both ends need to be identical – new/new and old/old NOT new/old, if the belt and the brushroll are OK then it may be the motor but I don’t think so. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 24, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
138 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
