Question about Maytag Dishwashers
The maytag dishwasher load sensing technology doesn't work. Lights won't even cone on what do I do to reset it
SOURCE: GE Max dishwasher no lights on panel
I have the same problem and actually found a workaround by mistake you may try as a temporary solution (if that works for you):
- press and hold the lock button for a couple of seconds
(the delay timer would increase by 1 hour)
- press and hold the lock button again
- repeat until it reaches 9hrs
- repeat one more time: the control panel should be functionnal again.
Let me know if that worked for you!
Posted on Mar 22, 2008
SOURCE: Maytag Dishwasher
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
Daniel S
  • 4323 Answers
SOURCE: The lights for the 'light
The control board seems to be bad and should be replaced. However, before replacing the board you can test the door switch located next to the control board, if it tests fine then replace the board. Hope this helps...please post back for further assistance.
Posted on Jun 21, 2011
  • 12223 Answers
SOURCE: Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Posted on Apr 02, 2013
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Dec 30, 2011 | Maytag MDB7749AWB Builtin Dishwasher
Please settle a dispute with my husband. my washer has an off balance load. do I have to remove things, or will adjusting the load eventually work to even it out?
the off balance sensor won't adjust the load,, it will notify you if the load is so far out of balance that it needs to be re adjusted . I hope this reply doesn't effect the rating I will receive :)
Jul 19, 2011 | Maytag PAV2300 Top Load Washer
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
Blinking "Normal" light on a Maytag model
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
May 19, 2011 | Maytag Dishwasher
Maytag mdb/c-2 some lights are blinking and won´t stop. I can´t start the cycle of cleaning, well really i can´t start anything. Please any sugestion ?
press the "off" button and hold it down for several seconds. this worked for me when i encountered the same problem on my maytag jetclean this weekend. it reset my control panel and now it's working great!
Sep 11, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher, flashing lights, frigidaire
Jan 20, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
252 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
