Question about Garden
How to get the tire and hub off of my MTD Pro Snow Blower. It has a Tecumseh 10.% HP engine.
HW_Dude
  • 87 Answers
SOURCE: tecumseh 8hp HIGH REVING! snowblower
be careful, if the engine over revs it may just explode. These engines are very picky if over sped and easily blow up.
Your problem may be a broken throttle control rod, have look at that first. If the control rods are fine and in place it could be the fly wheel governor is worn out.
Posted on Jan 10, 2009
SOURCE: Surging tecumseh engine on snow blower
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
Posted on Feb 01, 2009
  • 110 Answers
SOURCE: I have a snow blower with a Tecumseh 8 H.P.
SAE30 above 32F, 0W30 below that.
Posted on Oct 11, 2009
rwvanlue
  • 486 Answers
SOURCE: MTD YARD MACHINE SNOW BLOWER DOES NTO SHIFT INTO
Many times moisture attacks the hexagon shaft that the friction disc assembly slides on. It slides from side to side on the shaft to create Reverse 1 & 2, and the other end creates 1-6 forward. With a wire brush and sandpaper, clean the rust from the hexagon shaft, at the same time lubricate the friction disc bearing with penetrating oil and with a soft hammer, tap gently until the assembly starts to slide on the hexagon shaft. After all the rust is removed and disc assembly is sliding, apply a light film of graphite grease on the shaft. You may want to re-lubricate on a yearly basis.
Posted on Nov 22, 2009
  • 468 Answers
SOURCE: my mtd tradesman lawn mower does not run smooth.
These engines do not have an idle mixture adjustment. Most of the problems with them not running right are from bad gas, water in fuel, or carburetor jet deposits. If your fuel is ok, then you'll want to clean the carburetor metering hole. You'll want to either empty the fuel, or clamp the fuel line, but after that, take the nut off the bottom of the carburetor bowl. You will see holes both in the sides, and through the middle. Use a wire to clean these out, and some acetone or carburetor cleaner to get the rest of the deposits out, and you should be fine.
Posted on Feb 12, 2010
MTD snow blower model#31AH5WTG799 blades stoped turning
Look for a broken shear pin. It is usually a bolt that goes through the blade shaft and will break with an overload.
Feb 12, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Poulan Pro Repair Manuals
is it a snow blower, lawn mower or an engine problem ???
model number helps us, help you
Dec 27, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Tecuseth Snow King Engine. Starts fine. When I engage snow blower engine dies.
couple of things come to mind. Safety switch. Engine not running at full speed or snow thrower is locked smooth up
Dec 17, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Mtd snow blower 8 hp oil capacity
What engine do you have? Tecumseh those are usual 18-21oz Not sure with briggs, but will be around a 1/2 qt (16oz) start there. Add a little at a time to bring level up. get back if you have and need more specifics.
Oct 30, 2012 | Mtd Genuine 9460897 Snow Blower Auger...
I have a 10 hp Tecumseh Gold Series Snow Bolwer with 6 forward speeds and 2 reverse and I'm trying to find a owners manual for it, thanks.
If you locate the model number of your motor you should be able to download an Operator's Manual for the motor form this site:
http://www.tecumsehpower.com/
Is this an actual Tecumseh brand snow blower or another brand with a Tecumseh motor installed?
Jan 28, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
I have a 5hp tecumseh motor HS50-67324K on a craftman snow blower,could you please tell me the high and low RPM speed settings on this unit.
Here is a 70 page Tecumseh service guide. Locate the type of carburetor you have in the guide. All instructions with diagrams are available. This is a PDF file. Adobe Reader will be needed to view it.
http://www.smallenginesuppliers.com/html/engine-specs/tecumseh/Tecumseh_quick_reference.pdf
Dec 14, 2010 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Jul 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
