Question about Maytag Refrigerators
Maytag refrigerator no cool, no power on control panel, but lights inside
MFI2269VEM6, have lights inside, but no cool, no lights on display, if i press any button on display all lights light
    New Friend:
  • 16 Answers
Try unplugging or otherwise cutting power to the refrigerator for 30 seconds, and plugging it back in. If this doesn't work, you may have to contact Maytag for professional help or check this guide if you are willing to do it yourself: Refrigerator Has Power and Lights But Not Blowing Cold Air
Posted on Dec 13, 2016
Maytag refrigerator mfi2568aes replaced control board in back and input code and saved. now nothing is running but display is fine
Sometimes the new board will be in defrost mode when you install it, leave it powered up for 30 minutes to see if it begins cooling... Maytag Refrigerator Control Board W10890094
Also be sure the code is entered properly, these will do NOTHING without the right code.
Jul 08, 2016 | Maytag Refrigerators
My maytag mfi2269vem6 is not cooling. on the inside back of the freezer wall their is some ice build up one of the lines next to the compresser has ice on it.
Manually defrost the freezer so it cools and you can see what part of the defrost system has failed. Here is a link to your MFI2269VEM6 Refrigerator Parts List=> HERE You will need to insure the evaporator fan is working=> W10162809 Evaporator Fan the defrost Heater=> Defrost Heater Assembly W10166768 and the defrost thermostat which apparently is attached to the evaporator fan wiring. If all of this checks out you will need to consider replacing the control board=> Main Control Board W10310240 I am pretty sure the defrost controls are in the control board. I am here if you have questions,
Jan 31, 2016 | Maytag Refrigerators
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
Door Panel not working along with inside lights
check your owners manual to ensure it is not in the sabbath mode. if this is ok their could be a low voltage board problem behind the display or high voltage board in the rear of the refrigerator. unplugged the refrigerator before proceeding to repair it.
Nov 10, 2013 | Maytag MFI2269VEM 22.0 Cu. Ft. French-Door...
6 yr old Maytag getting warm
This could be the result of your refrigerator not defrosting properly. Look inside the freezer at the rear wall and see ice a layer of ice or frost is building. If the answer is yes then this would indicate a problem causing the refrigerator not to defrost. Hopefully it is only the=> 67002493 Defrost Heater Assembly
Instructions on how to test the defrost heater are found on the same page as the 67002493 Defrost Heater Assembly
Then there is also the possibility that the=> W10165425 Defrost Thermostat
If after testing these parts you don't find the problem then the problem will go to the defrost control found inside the fresh food compartment and behind the control panel=> W10207861 User Control and Display Board. I hope the problem is one of the two first parts I mentioned because the W10207861 User Control and Display Board
is expensive. I will be here to answer any questions you may have and assist you in you as you repair your refrigerator, Thanks Sea Breeze
Aug 16, 2012 | Maytag MFD2561HEQ Bottom Freezer French...
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
Control panel not working and no lights
Hi. you will need to replace this non functioning Control Panel asap and, test the light pressure switch for it's operational value. If the switch is OK, simply replace the bulbs.
May 24, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
Both compartments not cooling
It sounds like the control board may be gone. If there are no fans running or the compressor running then it will never cool of course. I don't think it's stuck in defrost mode since you say the display shows dashes vice numbers. Go to this site for diagrams, etc. Item 11 is the controls section.
Jan 28, 2007 | Maytag MCD2257HES Side by Side...
Refrigerators Logo
100 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
