Question about Hisense Televison & Video
Hisense TC 2181 A - Hisense Televison & Video
My hisense tv is on child lock . What should i do to unlock it????
doesnt a hisense have a 4 number pin someone enters
gee not sure ..try
Contact us Hisense Australia
see if the user manual is here
Downloads Manuals Hisense Australia
Sep 05, 2016 | Hisense Televison & Video
Hisense Remote
Use the "auto search" method to program the remote and it found a code on its own and get your tv unlocked. Try using 0478 code
Oct 17, 2008 | Hisense TC24FS2H TV
How to factory reset hisense u939
hard reset hisense - YouTube
? 1:56
https://www.youtube.com/watch?v=8HfCqq2ctwQ
Dec 11, 2013 - Uploaded by CELULAR CENTER ARMENIA
hard reset hisense ... 7:55. HISENSE HS-U939 Especially for Pandawill tech support team - Duration: 4:00 ...
HISENSE HS-U939 Especially for Pandawill tech support ...
Nov 29, 2015 | Hisense Televison & Video
Light comes on,flicker about five time and then goes off.than same happens again,but the tv don't comes on.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 10, 2015 | Hisense Televison & Video
Hisense led tv service senter in dubai
It seems there several Hisense mobile phone service centres in Dubai, but the nearest Hisense TV service centre is either in Amman (Jordan) or Muscat (Oman) - see Hisense
You could try to contact Hisense directly (by email) to verify that this list is up-to-date - try this webpage http://global.hisense.com/other/cous , click on map where it says 'middle east', this will give you a representative's name, address, phone and email
30.May.2015
May 30, 2015 | Hisense Televison & Video
Blinks red wont come had it diagnosted tech says main board
I had same problem with my Hisense TV. I replaced the "Main Board" and it's working fine. I took the TV apart and got the part # off the main board and checked ebay...found one! Good luck.!!
Apr 09, 2013 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I have a panasonic model number TC-P42X1 and i have no picture or sound. and the red light flashes every 4 seconds none stop
I had a similar problem with my Hisense TV and I replaced the "Main Board". Got the part on ebay. Don't know if this will help.
Jan 02, 2013 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
2181 code ecl on radiator fans dead
CODE P2181 COOLING SYSTEM PERFORMANCE MALFUNCTION CONDITIONS - ECT SENSOR HAS FAILED. 2.0L ENGINE ECT LOCATION IS ON THE UPPER RADIATOR HOSE CONNECTION AT THE REAR OF THE CYLINDER HEAD. 2.5L ENGINE ECT IS ON THE UPPER RADIATOR HOSE CONNECTION ON THE CYLINDER HEAD ALSO.CHECK COOLING FAN FUSE AND RELAYS
Jul 26, 2009 | 2003 Volkswagen New Beetle Convertible
Service mode for hi sense tc3418uf
Hit the menu button. By hitting the volume button once you will see a menu to adjust TV. Click down by hitting channel to TV frame. Click adjust volume.
Oct 30, 2008 | Hisense TA42P40M 42 in. Plasma Television
Televison & Video Logo
16 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
