Hi, need to check the exchange i placed - Computers & Internet
Hi there, I have a H23 fault code up on my CS-E24PKR Panasonic inverter AC. Could you please advise what to check relating to the Indoor heat exchanger temperature sensor?
The system has already determined that the thermistor is faulty so I wouldn't bother checking it as they are cheap and easy to obtain. The thermistor in question is one of two located at the right hand side of the indoor heat exchanger (the metal radiator-like assembly). One is the air temperature sensor and the other is the pipe/heat exchanger sensor. The air temp. thermistor is the one just in front of the heat exchanger held by a plastic clip. The pipe/heat exchanger sensor is the one that sits in a small metal tube near the copper pipes leading to the heat exchanger. It is usually a fairly tight fit because of a small metal insert to keep it in place. Use some small needle nose pliers on the metal insert to pull the thermistor out - NOT THE WIRES! Of course, make sure power to the A/C is completely off first.
You will probably have to replace both of the thermistors as they usually have the wires going to the same single plug on the controller board.
Dec 17, 2016 | Panasonic Heating & Cooling
Hi, I have just bought an LG MS4042GRS microwave which has intermittent vibration still day 1, but when I put my hand on the top of machine vibration stops. Is this normal?
Kim, I would say no to the vibration, return to place of purchase for exchange or refund. My 8 year old microwave does not vibrate, so a new one definitely should not.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jun 01, 2016 | LG Washing Machines
Do I have to pay to return a parcel
No you don't. Returns are free.
How to Exchange or Return your Order
To exchange your order or return for a refund, please follow these simple steps:
Contact our Style & Care team:
1 866 440 7948
styleandcare@shoeme.ca
Let us know if you would like to make an Exchange or Return.
Our agents will process your request and issue your Return Waybill and Return Slip. If it's an exchange, our agent wil re-order your product.
Complete the Return Slip by filling in the order number, item name and reason for return. Include the completed form with your shipment.
5
Place return item(s) in original shoebox.
Your item(s) and the original shoebox must be undamaged to qualify for a return.
6
Place shoebox in original or new shipping carton. Attach the Return Waybill label to the outside of the shipping carton.
7
Ship your return back to us.
Refer to the email you received from SHOEme which contains the Return Waybill and follow the instructions.
8
Provided your return meets our requirements, our Returns Team will then ensure that your refund or exchange is processed as soon as possible.
You will? be? notified vie email once we ?complete your return.? R?eturns are processed within 4 business days? from us receiving them.
9
Please allow an extra 3-10 days for the refund to appear on your credit card or PayPal.
Oct 03, 2015 | Minnetonka 3902 Pile Hardsole Pile Lined...
Induction fault e6
E6 - Defect Induction module or over temperature of coil sensor with Falcon User interface with production date before 2010
- Disconnect the appliance from the mains for 30 sec. If alarm still occurs after 1 min operation exchange induction module.
Over temperature of coil sensor with Falcon User interface with production date before 2010
- temperature sensor defect or wrong mounted.
  1. Check connector at induction module.
  2. Check the coil sensor, it should be placed even in the silicon carrier.
  3. Appliances with 3 zones, is the "Dummy" temperature sensor at the 2nd terminal mounted?
  4. Exchange coil with sensor.
  5. If above is without success, exchange induction module.
Dado
Jun 03, 2014 | AEG Ovens
Euro-pro hark steam mop
Check the manuals link and call them...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jul 12, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
We have a miele dryer T 234 C and a recent has
Hi most likely seals on heat exchanger (condenser unit).
Lock heat exchanger in place.the should no movement at all.if movement you will require a rear seal for heat exchanger.Where heat exchanger seals in condenser box clean with scourer. check bottom of door seal for debris.
Mar 23, 2010 | Miele Novotronic T220 Electric Dryer
Recently I put a new heat exchanger on this H400 hayward heater. Went back out to check on it and the lights were not on anymore. So I checked the hi limit and replaced it and the heater worked agian. Went...
High limits are safty switches to keep the heater from over heating and runing your new exchanger. you will need to check the by-pass inside the water manifold. It could be the problem but hook up the limits in the mean time. As you are aware at this time the exchanger is your most expensive heater part you can buy.
Mar 22, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have a hayward H200 series heater and th eheat exchanger is leaking. I have pulled the heat exchanger out and cant see anything visible it is probably leaking inthe area covered by the fins. I have...
You need to buy the whole unit as these are pressed in place together. If you have a leak it is most likly due to chemical damage and goes further. So at the least you will need an exchanger. I will usually try to get people to go with a new heater if it is more than a couple of years old due to cost and hidden damage that can only come out after you install a new exchanger. Sorry for the bad news.
Mar 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
