Question about Pool & Spa
My easypak was working fine but I moved the spa in my basement and plugged it in and it wouldnt turn on but it was working fine before i moved it. Can you help me
We moved our Kitchenaid refrigerator down the steps to the basement using a dolly and now its running constantly.
I can't think of any reason moving it would cause that problem. How are your door seals? Are both fans(evaporator fan in freezer and condenser fan at compressor)working? Did you give it 24 hours for temps to stabilize?
Oct 16, 2017 | KitchenAid Refrigerators
EasyPak 1000 Flex-Fit Air Spa Control System. Everything works fine, except, when plug in heater power. Gfci trips. When unplut heater power, everything works
GFCI blows because you have a short to ground. Check your wiring for loose connections and your heater core element.
Mike
May 29, 2017 | Pool & Spa
I have not used my Robo Kleen for several years. It was in storage in the basement. I put it in the pool and at first only moved a couple of inches. I manually rotated the wheels and they are very...
try keep working the wheels, it might free up. should be a easy fix. good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 11, 2013 | Smartpool Dolphin Robo - Kleen Above...
So we have the jandy laars lx.... we have had it for 3 years no problems we use it with pool and spa and its gas........ the buttons work you can choose pool or spa just fine but when you choose one... the...
This heater wont start if the pressure switch is bad or clogged. Remove the pressure switch and clean it out really well, or just purchase a new one. It should only be $30-$50 depending on where you go to get it
May 03, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Home heating issue! hot air is cold when it reaches top floor!
Just guessing, but I'll bet your 2nd floor duct work is in the attic, and uninsulated, wrapping all attic mounted duct work with R-13 insulation and sealing it with tape will help but there is still going to be a slug of cold air pumped into the upstairs rooms each time the furnace cycles.
Dec 11, 2009 | Better Living SPP High Efficiency...
Washer outlet hose - how high can it pump?
sur thats a fine height, i wouldnt go past 8ft
Jan 26, 2009 | Kenmore 24032\24036 Top Load Washer
Pool & Spa Logo
73 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
