Question about Duracell 1500W Power Inverter (D1500) 500-Watt Power Supply
My new Duracell Powersource 1800 fault light came on during the second "seasoning" discharge and I can't get it to go out so I can charge it again.
  • 66 Answers
Seat ibiza faults
Check alternator charge rate and earth straps
Jun 19, 2014 | 2007 Seat Ibiza 1.2
Need DC car adapter for Duracell powersource mobile 100
the positive pin is the one to the right when looking at the power connector with the mobile 100 standing up correctly, the negative is the one at the far left. I made mine start charging this way: Still don't know what the middle pin is for. Just make your own cable out of an old car plug and possiblly a pc power source connector. it's not that difficult.
Apr 20, 2013 | Xantrex Technology Duracell Powersource...
I don't know if my unit is charging.I have plugged it in for over 16 hours and it still flashes chg.
If it is new, you might need to open up the battery compartment and make sure there is not a removable protective covering on the battery leads. Otherwise it may be a defective battery. Many times the manufacturer will warranty it if you call them.
Mar 04, 2011 | Xantrex Technology xPower PowerSource 1800...
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
I bought KODAK NiMH 2400 mAh and it isn't rechargeable when I recharge it it jus work for few minutes.
NiMH tends to have a "memory". What this means is that the batteries will get used to being only charged and discharged a certain amount. What could be happening is that the battery THINKS it is charged when it is not... or.. it THINKS it is discharged when it is not. You can try to recondition them:
  1. Charge them
  2. reset the charger and charge again
  3. put them in your device and drain them
  4. let them sit, drain them again
  5. recharge them
  6. drain them again
Do this a few times. If you don't notice an improvement, you may want to consider getting a new set of batteries - I would recommend lithium rechargeables.
Jul 11, 2009 | Duracell NiMH AA/AAA Battery Charger with...
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
My duracell crank light 3 in 1 is not working properly. I rotated crank handle for about a minute or 2 long,thinking that charging would be enough and led torch will light for few minutes during power cut...
I found with my Duracell crank lights they periodically need a good charge to function well. On the side there is a 5v charger socket - suggest and 8-10 hr charge. There is also a USB with a switch between IN and OUT. With a suitable USB cable in the IN position, the light can be connected to a computer to recharge. Hope this helps.
Jun 27, 2009 | Duracell Crank Light 3 In 1, 3 Led...
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
Duracell 1500W Power Inverter (D1500) 500-Watt Power Supply Logo
226 people viewed this question
Top Duracell Computers & Internet Experts
Rick Moore
Rick Moore
MrFixitSTTL
Bill Boyd
Are you a Duracell Computer and Internet Expert? Answer questions, earn points and help others
