Question about Electrical Supplies
How do u set the carb on a2.4up champion generated? Thanks.
  • yadayada
    yadayada Dec 13, 2016
    Hi Mike Joseph romero, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Sergeant:
    Habit-Forming:
  • Electrical S... Expert
  • 153 Answers
We have engineers who can help you. Contact us via our chat on our site. Parts Spares for Generators and Small Engine Machinery
Posted on Jan 03, 2017
2 Suggested Answers
protek480
  • 1723 Answers
SOURCE: my champion 3500w generator stops all of a sudden
How long does it run? The 'oil pressure' switch will cause that....??
Posted on Sep 11, 2009
Bad gas champion 6800 generator
You need to:
1) replace the fuel in the tank
2) Remove the petcock and clean filter located on top
3) Rinse out tank with clean fuel
4) Clean the carb (replacement carb or carb rebuild kit might be required if damaged by ethanol in fuel)
5) Put it all back together and run the generator.
If you do need a carb or carb repair kit you can purchase them on our website:
http://www.generatorguru.com/champion
Nov 27, 2016 | Electrical Supplies
How do I fix my generator when I get gas in my oil?
This comes from gas getting from the carb when the engine is stopped. The carb will need a good cleaning. Kawasaki has vent tubes just to avoid this when air venting gets plugged. Just saying. ..
Oct 29, 2014 | Champion International Electrical Supplies
Starts and runs fine until you open choke dies instantly
Carb has debris. Take float bowl off and clean and if that doesnt take care of it-clean carb completely
Jul 26, 2014 | Champion 3500/4000 Watt Portable Generator
My generator runs at too high a speed
screw anticlock wise speed regulater on the carborator
May 10, 2014 | Champion 3500/4000 Watt Portable Generator
Champion 3500 generator how to fix stuck float
It could be a carburetor problem or it may be the low oil cut off switch. Check to make sure oil level is up. If it is check the needle valve attached to the float and the seat. The old carbs used to have a brass seat. Some of the new carbs have a rubber seat and it may need to be replaced. Hope this helps.
Dec 31, 2013 | Champion 3500/4000 Watt Portable Generator
This gen won't start , good fuel, carb good get's air & fuel spark plug new. any ideas
if it has air fuel and spark then check the compression. if it has all 4 of those then it will be a timing issue but I am willing to bet you are missing 1 of the 4.
Sep 28, 2013 | Champion Fulfillment Champion 2000 Watt...
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
Electrical Supplies Logo
23 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
