Question about Garden
Homelite 2600 Pressure washer stalls while in use
Starts up fine, after a few minutes with the wand engaged, it will act like it wants to stall. If I let off of the trigger, it will regain itself and start the process over again. if it does stall, again for a few minutes, it will run fine, then start to want to stall, I let off of the trigger and most times, it will regain itself. I have run it with a loose gas cap and no gas cap and it does not change the problem. the oil level if almost full and it is on level ground.
    Top Expert:
  • Garden Master
  • 45,654 Answers
Problem appears to be blockage in the main jet or low fuel flow to the carby
clean out the main jet and bowl ( could be water or dirt in the main jet)
check the fuel flow through the tap as they can corrode inside and block the flow or the filter in the tap inside the tank could be blocked
Posted on Dec 13, 2016
Testimonial: "Thank you!!! That is along the line of what I was thinking as it seemed to be a fuel issue, although I read of other possibilities. will look to see what it takes to take the gas tank off and go from there. will advise what I find."
Engine stalls when not using wand
Frank, either the unloader valve is out of adjustment(try loosening it off) or it is faulty and needs rebuilt or replaced as most people do.
Check the attached vids,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 15, 2016 | Honda Black Max 2600 PSI Pressure Washer
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
Power washer will run fine for about 30 to 40 minutes then stalls, I wait a few minutes and starts but it runs rough and stops.
Sounds like a fuel problem eighter a filter or you have debrie in your fuel tank thats cloging the inlet from the tank to the carburtator . Its that or a problem with the water pump . That could also be clogging and putting exesive back prressure on the engine shaft causeing stalling . What dose your water flow look like do you loose that first before the engine starts to bog down or dose the engine go first and the pressure follow . Also do you winterize the mechine i owen and repair many washers if you need more info you need to give more pier_j
Feb 20, 2011 | Dewalt DPH3100 Gas Pressure Washer
Engine satlling
If it acts like this with the hoses disconnected, I would guess that either you got bad gas, or if it was sitting for a while before this, that there is varnish in the carburetor and when the choke goes off it starves for fuel. I would try Seafoam or Gumout to dissolve it before taking it apart and mechanically cleaning it. If it only does it with the hoses attached, it may be an unloader valve in the unit that is sticking. Good luck.
Apr 26, 2010 | Honda Black Max 2600 PSI Pressure Washer
PWER WASHER RUNS PERFECT, WHEN WATER COMES ON, IT STALLS. BUT IF YOU PULL TRIGGER BACK ON WAND, THEN SPRAYER WORKS. THE MINUTE YOU LET GO OF TRIGGER, IT STALLS OUT.
hi you have got a fault with the unloader it's not unloading so its going a bove the 13amps and knocking the thermol overload out or blowing a fuse you could cable tie the trigger open or get a new unloader kit costing about £70.00 regards
Feb 17, 2010 | RTO 1800 PSI Pressure Washer
Engine stalls when I release the wand handle (stop water flow from wand).
this is because the pressure is wound up too high ,if you back the pressure off abit you will solve the problem. if your machine has a pressure gauge ,you will be able to see the pressure needle"spike" when you release the trigger.that is the needle jumps right up high that is when motor stalls if you adjust the pressureso that the "spiking" effect is minimal your machine will not stall ,..I hope that helps
Aug 14, 2009 | Garden
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
Garden Logo
852 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
