No am on my radio just static
Fm and xm work ok just static on am
sTatiC00000L
  • 8 Answers
SOURCE: MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Posted on Sep 28, 2008
arclight1217
  • 208 Answers
SOURCE: am radio not working
THIS SOUNDS LIKE YOU HAVE A RADIO PROBLEM. IT MAY BE WORTH YOUR TIME TO HAVE A DODGE DEALER CHECK THE RADIO TO SEE IF INDEED THE RADIO IS BAD, BUT THEN YOU HAVE THE OPTION TO REPLACE THE OEM RADIO WITH A NICE AFTERMARKET RADIO. THESE HAVE COME DOWN IN PRICE DRASTICALLY AND ARE PROBABLY CHEAPER THAN REPLACING THE OEM RADIO. WITH NO SIGNAL OR STATIC ON THE AM BAND SURE SOUNDS LIKE THE AM BAND IS DEAD. IF I CAN HELP MORE REPLY TO: ARCLIGHT1217
Posted on Nov 14, 2008
thepartspros
  • 36 Answers
SOURCE: No FM reception on factory 1996 dodge grand caravan radio
replace the attenna if that does not work the radio is the problem
Posted on Jul 16, 2009
rtpflh
  • 546 Answers
SOURCE: The AM/FM radio in my 2003 cadillac CTS faded to only static
check antenna cable connections at radio & antenna.suspect power antenna if equipped.
Posted on Sep 30, 2009
SOURCE: FM radio on Sansa Clip does not work
Have you muted the radio by mistake.If you have there will be a square symbol under the FM sign.Press the top of the ring.
Posted on Jun 07, 2010
My old unit stopped working;(worked perfect for many years) so I replaced with a new same model and I have bad interference and FM static. Sometimes the FM station overrides the express radio and all you...
The very first XM radios, (SkyFi2, MyFi, Roady2) up until they were put in red boxes, had a VERY strong FM transmitter, so strong, that when Sirius was their enemy, they complained to the FCC and they made the FM transmitters real weaklings. So unless you have one of the first two batches of XM radios, the FM transmitters now are real junk and you're better off using an AUX input on the radio or a cassette tape adapter. Okay? Thanks.
Mar 26, 2015 | Audio Players & Recorders
Xm radio wont work on toyota fj
hummmmm sounds like maybe you aren't paying for the service anymore .
Mar 11, 2015 | XM Radio Car Audio & Video
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
New Xm, went through the steps in manual; no sound in car
The stations you set it to have to be complete static for the xm to come in. Your best bet if you head unit has an aux input is to buy an aux cable(few dollars) and hardwire it. it will give you the best quality for sound for xm.
Dec 27, 2009 | XM Radio (XMP6000)
Xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
Static sound or no sound with FM Trans and with Audio Plug
I agree with you. It sounds like an internal audio circuit problem, especially if the tape adapter does the same thing. Have you tries headphones on the unit? If they work, then get the sure connect as it plugs into the headphone jack (Aux out jack)
By the way, you as an XM customer for years, usually XM will just give you another unit to keep you as a customer. I've seen it many times. Couldn't hurt to ask!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 23, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
Jan 22, 2009 | Car Audio & Video
IF:
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Panasonic CQ-DF903U How do I hook up my Sirius Radio to it?
Sirius radio connects via a special dock. Sorry, but you're screwed with your XM unit...
Apr 05, 2008 | Panasonic CQ-DF903U CD Player
65 people viewed this question
 Grubhead
Grubhead
