No am on my radio, fm and xm are ok - Audio Players & Recorders
glennsimoes
SOURCE: I get no audio from
The antenna wire was broken on the back of the radio.
Posted on Apr 30, 2009
SOURCE: xm radio
Looks like my company is going to purchase a new fm radio for the company truck, I should be able to plug the xm radio into it.
Posted on Jun 04, 2009
available269
  • 41 Answers
SOURCE: how do I tune FM frequency to play roady xt xm on
Tune in 88.7 fm
Posted on Apr 26, 2010
TOLhamRadio
  • 509 Answers
SOURCE: what frequency should car radio be on to access xm
Go to your radio's MENU and set a frequency, then set your car to the same frequency.
Posted on May 27, 2010
jtcasejr
  • 6 Answers
SOURCE: I own an Eton E1 radio equiped with AM, FM (and XM
The E! excels with external antennas. Best results come from an active loop. The Wellbrook ALA 1530 is excellent and what many serious SWL use. Also, there is no built in ferrite rod antenna for MW as the display generated too much noise to include. Using a C.Crane Twin Coil Ferrite Rod external antenna makes this radio an Alpha MW DX performer.
Posted on Nov 20, 2015
My volume on the xm radio band is noticeably lower than the regular fm band. Is there anyway to adjust the volume on the xm band tto make iy louder?
XM radio usually has lower volume than regular FM/AM bands. But there 'might' be an adjustment you can do with your radio, depending on your unit. Please indicate the brand and model of your radio so I can check.
Sep 24, 2011 | Car Audio & Video
Delphi skyfi2 Xm Radio Receiver car connection
Yes, you can buy an FM Direct adapter that will allow you to transmit directly to your car FM tuner, but if you have an older SkyFi2, the Fm transmitter is so strong, you can sit the radio on the floor and tune your car radio to your preset XM channel, like 107.1 FM and it will work great. Go into "Menu" and pick a channel that's not used locally.
Jul 12, 2010 | Delphi SKYFi2 SA10101 XM Radio Receiver
Roady XT XM Radio Receiver: how do I change the radio station i want my xm to ...
First of all find a clear fm stn. on your car radio.Go to xm radio and push menu until fm freq. shows up.Push sel and use up or down arrows until the freq. matches that on car radio. push select again to set it.
May 07, 2010 | Delphi Roady XT XM Radio Receiver
XM Radio in 2008 Hyundai Sonata sounds bad
Same problem here. I repeatedly complained to XM but got no reply. I listen to XM in 2009 Sonata and it was just as bad.
XM is better than AM. Much worse than FM.
Oct 14, 2009 | 2008 Hyundai Sonata
Xm radio
Jun 03, 2009 | Delphi SKYFi XM Radio Receiver
How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
Jan 22, 2009 | Car Audio & Video
MyFi FM Modulator Stopped Working?
hi there..there are few ways on installing xm into your car..you can use the FM Modulation that you're doing before..it goes like this...make sure that you're xm radio is turn off( with all the wirings unplug).....then, you just have to go on a blank channel(e.g 90.1) on your car radio...afterwhich, turn on your xm radio and go to MENU....and look for FM settings...and select the same frequency you have into your car radio...and just have to wait for 5 to 8 secs and you should be getting the prev. channels.....
IF: you're only getting prev. channels such as 1, 130 etc...you just have to call xm to send a refresh signal OR you can go to www.refresh.xmradio.com if you want to save more time...just type in your 8 digit radio I.D....
IF:
you're not getting the FM settings.....you just have to click the MENU and select the 'default settings/factory settings' then turn off/on your radio to save the changes...
i'm sure it'll work nowq at this time....Godbless!
Aug 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Alpine CDA-9856
Do you have to run in AUX to get XM Radio? Your receiver and unit sound like its ok. This could be a problem with your provider. Contact your provider and their tech dept can help you organise a solution. Is your radio, XM ready?
Mar 09, 2008 | Alpine CDA-9856 CD Player
67 people viewed this question
 Grubhead
Grubhead
