Question about Home Security
I bought and installed the light below at home depot. It worked for a week. Now it still has power, bulbs work but the motion sensor doesn't activate the lights
Defiant LED motion security light 180' light #1000 048 906
  • 14,534 Answers
Take it back, its faulty.
There is a sensitivity setting somewhere, try moving all the way up and then down a bit.
Posted on Dec 13, 2016
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
My motion security light keeps blowing only the left side bulb.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Converting outside recessed lighting to a motion sensor
You will need to add a motion sensor in line between the power source and the light.
May 17, 2013 | Cars & Trucks
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
My 600 watt 12 volt transformer timer for out door lighting does not keep time properly. HOw do I get and install a new timer?
1) Amazon sells 600Watt power pack:
http://www.amazon.com/Malibu-8100-9600-01-Voltage-Power-Transformer/sim/B002ZRPM4A/2
2) I bought new 300Watt Malibu power pack at Home Depot about 2 months ago.
Near the lighting section.
My new power pack has electronic time clock, so no more 'slow clock.'
I think Home Depot had 600Watt.
Lowes carries different brand.
3) Manuals for power packs at Malibu lights.com
http://www.malibulights.com/customer_service/owners_manuals.aspx
4) Tips for buying and taking care of power pack:
-Match up wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
-Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
-Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
-When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
5) How to install power pack.
Before unplugging old power pack, check which bulbs are not working.
Replace bulbs using phillips screwdriver.
Unplug power pack.
Notice how wires are connected to power pack, write down terminal connections.
Some power packs have three terminals ... extra terminal is for additional photoelectric eye.
Use pliers or screwdriver to disconnect wires.
New power pack has has same terminals.
Plug in power pack.
Read instruction manual before connecting wires.
Save instruction manual because a few years that manual won't be around as products change.
Dec 03, 2010 | Malibu Intermatic Inc. ML121RT Low...
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Heath Zenith Security Light fixture with motion stopped working.
I am in the middle of a discussion with Heath/Zenith over a closely related and perhaps identical issue. I purchased their 5718 model from Home Depot and based on the fact that their brochure stated that "CFL bulbs are only usable on 270 degree units." I purchased the model 5718 unit (270 degree) and used CFL bulbs. It experienced the same problem others noted.
The technician at Heath/Zenith told me that only DIMMABLE CFL bulbs would work with this unit (even if the DualBrite feature is turned off). Standard CFL bulbs will not work.
Their brochure does not make that clear. Perhaps that is the answer to others' problems.
Nov 12, 2008 | Heath Zenith SL-6136-WH Basic Solutions...
Light bulbs burn out after a few days in garage door opener, craftsman 1/2 HP double lights. have used every kind out there, specially made for garage doors, etc.
Try REVEAL brand DOUBLE LIFE ceiling fan light bulbs, available from HOME DEPOT. The filament in those bulbs is much thicker than any others, and the one I installed on my own Sears GDO has lasted 3 months so far, compared to one week for others I have tried.
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
81 people viewed this question
Top Home Security Experts
Are you a Home Security Expert? Answer questions, earn points and help others
