When i put one dvd or Cd in the display Show Loading then ERRO disc whats happening?
    Top Expert:
  • Televison & ... Master
  • 8,204 Answers
If the discs did play before this happened you might need to have the laser inside cleaned,
get a laser disc cleaner and run that through it.
Posted on Dec 13, 2016
SOURCE: GPX d2816 problem
hey i know what it is ...i had the same problem and i took the top off and found the whole carriage for the disc inside has slotted holes and is adjustable.i simply moved it around until it worked then tightened it into place. hope that helps...... good luck badsdaddy
Posted on Aug 21, 2007
SOURCE: Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Posted on Dec 21, 2007
  • 286 Answers
SOURCE: dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Posted on Feb 14, 2008
  • 814 Answers
SOURCE: Does not work always says check disc after loading
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shiney. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not applie to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laserhead and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
Posted on May 30, 2009
  • 35 Answers
SOURCE: Coby TF-DVD7100 (portable dvd player) says "no disc"
when it says wrong disc, optical pickup assy needs to be replaced J.D.W.
Posted on Jul 12, 2009
I have a samsung dvd-v4600...and when i put the dvd disc in it just keeps loading and will not load ..what do i do to fix this?
Does it do with original DVD or copied DVD ?.
if the original one works fine but the others not, your DVD may not capable of playing copy -R/RW discs..even though your DVD specs says: Plays DVD-Video, video-mode DVD-R/RW and DVD+R/RW, CD-R/CD-RW, MP3 CD, Kodak Picture CD, and JPEG image CDs, sometimes this happens due to bad recording of DVD .Try to use better recorded DVD or if possible use the original ones..
Thanks in advance for rating me..Regards
Oct 22, 2010 | Samsung DVD-V4600 DVD Player/VCR
Denon 2910 CD player malfunctions
is this happening with all the cds??
the case may be with the cd sometime..where the tracks wouldnt have been properly completed...
Jul 13, 2008 | Denon DVD-2900 DVD Player
You have not said the TYPE of CD or DVD you are trying to play.
Your manual will clearly state what can be played and what cannot. ALSO, some mfg's like mine (samsung blu-ray) provided software or firmware updates you can d/l to flash drive or burn on cd and insert.
Check manual and your mfg websit for what's available.
May 20, 2009 | Cyberhome CH-DVD 300 DVD Player
My DVD player has worked excellently for almost 10 years. Uncertain if that's the problem. All the buttons on the remote and on the front panel seem to respond--one way or another. This is a Sony CD/D
by a new player i recomend sony,there still the best. dont waste your money on blue ray,they will be obsolete in five years and they are very slow,ie. loading and reading discs, i know i sell them
May 19, 2009 | Televison & Video
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
Nov 25, 2007 | Televison & Video
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
you could try this or clean the lens
Nov 06, 2007 | Denon DVD-2900 DVD Player
Loading...loading...loading...(10 minutes later) disc
I just fixed this problem. This will not fix any underlying problem, but it will get you up and running again. THIS MIGHT SCRATCH THE CD.
Unplug the unit. Remove the top cover. There are screws on the side and the back. Once you do you will see the dvd is not in correct position. Slide it around till you feel it drop into place. YES, YOU MAY END UP SCRATCHING THE CD. Plug the unit back in and it will eject.
For me the underlying problem is that the disc drawer closes while I am putting the cd in, causing it to not be seated properly. If anyone knows how to fix this .....
Apr 25, 2007 | Apex Digital AD-1225 DVD Player
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
