Setting mode on 150 series - Office Equipment & Supplies
Put batteries in a highland series 150
I'm not familiar with this particular torch but similar torches use an adaptor such as one depicted below to enable AAA batteries to be used where the primary battery is either a 18650 battery or two CR123 batteries in series. I hope this helps.
Sep 21, 2014 | LifeGear Life Gear Highland Series 150...
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Hi, Although I have N series ADSL2+ Router and a N
N series routers can communicate at a speed of 150 Mbps, only if the wireless adapter that is built-in into the computer comes under N standard...
Most of the wireless adapters comes under G standard, which can communicate only at a speed of 54 Mbps...
The N standard routers are backward compatible, which can communicate with N standard adapters at 150 Mbps, and with G standard adapters at 54 Mbps and with B standard at 11 Mbps...
The speed in which the adapters can communicate are listed below...
B - 11 Mbps
G - 54 mbps
N - 150 Mbps
Dec 23, 2010 | Computers & Internet
Audio problems with Alesis RA-150
on bridge mode the speaker impedance should be 8ohms, less than this clipping will happen. try bridging two 4 ohms in series.
if this happens without speaker connected, u have a power amp section that is trying to draw more power than it can handle.
as for the second check connections first, otherwise i suspect u have a defective power amp for the right channel.
Mar 12, 2010 | Alesis RA-150 Amplifier
Manitowac Series 150, not producing much ice, cycles itself off.
Use a fan to try helping it stay cooler but make sure coils are clean and refrigerant is not low if it has a temp setting turn it down
Nov 06, 2009 | Manitowoc MAN-KF3 Koolaire Freezer reach...
Power acoustik gothic OV2 800 manual
Could not get a manual for you but did get the follwing specs. Hope they help.
Power Acoustik Ov2-800 2-Channel Class A/B Gothic Series Amplifier (800-Watt)
POWER ACOUSTIK OV2-800 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER
800-WATT 2-CHANNEL
4 ohm RMS: 150W X 2
2 ohm RMS: 180W X 2
Bridged mode MONO RMS: 360W
BRIDGED MAX: 800W
FULL MOSFET POWER SUPPLY
PWM CIRCUITRY
FULL SELECTABLE CROSSOVER
3-WAY PROTECTION CIRCUIT
TRI-MODE CAPABLE
VARIABLE LOW PASS 40 HZ - 120 HZ
VARIABLE HIGH PASS 150 HZ - 1.5 KHZ
VARIABLE 18 DB BASS BOOST @ 40 HZ
FREQ RESP: 10 HZ TO 30 KHZ
S/N RATIO: 98 DB
THD: 0.02%
2 ohm STABLE STEREO
SYSTEM DISTRESS INDICATOR
HIGH/LOW LEVEL INPUTS WITH FLOATING GROUND
4-GAUGE POWER/GROUND CONNECTION
PLATINUM RCA CONNECTORS
LINE OUTPUT WITH FLOATING GROUND
BLUE LED
CHROME TOP PLATE PANEL 2-CHANNEL CLASS A/B GOTHIC SERIES AMPLIFIER (800-WATT)
Aug 18, 2009 | Power Acoustik GOTHIC OV2-800 Car Audio...
I can't figure out how to adjust the bass on the JVC KD-HDR30.
Hello hawk713, Like with many other JVC receivers, adjusting the bass is done from the "EQ" (equalizer) mode for one or all of 6 presets: ROCK, CLASSIC, JAZZ, HIP HOP, POPS, and USER. To adjust it, select the desired preset mode, use the left/right rocker (on volume control) to scroll to the desired frequency, 60, 150, 400, 1K, 2.4K, 6K, and 15K, and then turn the volume control up/down to set a level from -5 to +5. 60 and 150 adjusts the bass, 400, 1K, and 2.4K adjusts the midrange, and 6K and 15K adjusts the treble. Then you select whichever EQ setting sounds best with the particular music you're playing. Hope this helps.
Jun 06, 2009 | JVC KD-HDR30 CD Player
Play and recording both are not functioning.
Is not a setting you need to send to repair try contact www.tvps.com they have a icredible special
Mar 23, 2009 | Sony TCM-150 Handheld Cassette Voice...
Quality mode setting
Press the monitor button. The amount of images that can be stored and the selected quality mode will appear in lower-left corner of the LCD display.
Aug 31, 2005 | Olympus Camedia Brio D-150 Zoom Digital...
13 people viewed this question
k24674
jasbo
jasbo
