Question about TORK Hardware & Accessories
Programming a Tork Digital Time Switch Model DGLC
How can I find a programming booklet for this model? I can't even find this model anywhere online.
How to set a tork timer
1) Copy following link to identify timer, and download possible manual:
2) Tork TU universal
3) Usually the dial will rotate manually until current time lines up with Time arrow located next to override lever, or time arrow located on inner dial, depending on model number.
4) Tork DTU digital timer:
5) After opening links to identify timer, add comment and describe where you are, and what you discover.
Feb 20, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
How do i program a tork dtu40 timer
1) Copy following link for programming manual and wiring Tork DTU40 40amp timer.
2) The timer mechanism is old Intermatic/Grasslin/GE discontinued model, and then newly re-minted by Tork in 2012. Timer has 1 year limited warranty against defects in workmanship. This timer is protected from surge by the reset feature, but can burn out in heavy surge event. Non-replaceable Internal rechargeable battery retains programming until timer is reset. Always reset new timer to delete trace memories.
3) This timer can be wired many different ways, and timer automatically detects voltage, so there are no dip switches to set. Timer must be wired before power is turned on. Do not spark-test across terminals.
Feb 17, 2013 | TORK Hardware & Accessories
The supplier that fiited my swimmimng pools timers never gave me the booklet on how to set the time.
1) Unknown brand name pool timer, probably Intermatic:
Unknown if this is mechanical timer, or digital, or remote control, or air activated. Or if this is control center with circuit breakers and multiple timers to control heater, and pool pump, or if unit has firemans switch to turn pool heater off 20 minutes before pool pump, or if unit has freeze protection thermostat, etc
2) For Tork:
3) Jan 2013.
Add a comment with model number or attach photograph and add any other information available for best possible answer based on specific product.
Jan 02, 2013 | Hardware & Accessories
Onesto timer switch pts20a programing details
PTS20a is 20 amp version of Onesto din-rail mount7-day digital timer:
If you're searching for product manual, then there is no product manual posted oct 2012.
If you own this timer, then describe the buttons, and I can locate same-similar timer based on that description.
Frankly the product looks very similar to Intermatic Talento 400, or Tork DIN rail series.
But usually, to avoid patent conflicts, the Chinese knock-off product will have one or more button that is different.
Even with small difference, the programming will follow similar pattern, since all these timers do the same basic job.
Copy following links to help identify possible manual.
Oct 04, 2012 | Hardware & Accessories
Tork model dts200a/dzs200a shows no display and has stopped working. any Suggesqtions?
Tork DTS200a/DZS200a is 2-channel digital timer with 365 day programming and astronomic capability.
2-channel means that timer can control two different circuits with different program schedule applied to each circuit.
1) Timer has 'snap-in non-rechargeable 9-volt lithium battery'
Replace with ordinary 9 volt battery
Battery location is not apparent from image of product, and I don't own this particular timer line.
Add a comment and say where battery is located.
2) Programming is stored indefinitely in memory chip even if battery goes dead.
Current time might have to be reset shown in manual page 3.
Memory can be cleared using procedure outlined in manual starting page 13.
3) If timer function is not restored, then timer might have gone bad.
Contact NSI:
Many timers and other electronics are not protected from power surge.
Lightning strikes, electrical storms, and simple power outage can knock out electronic timers, and water heaters, water softener, treadmill, etc.
1-event Surge protectors can be installed in main panel to help protect circuits and electronics.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | TORK Hardware & Accessories
I have just had an avital remote starter installed in an '04 Ford Explorer (Model 4103). The second day I had it the car will only run for a 30seconds and then it just shuts down. Any assistance is...
i have the same remote starter on my vehicle. there are programming options and saftey shut off features the programming options are all in the booklet on how to program and reset programming. some safety features may not have been completly installed like the tach signal reference, hood safety switch, brake switch, etc. if this was professionally installed i would contact the installer for warrenty. hope this helps
Feb 03, 2011 | Ford Explorer Cars & Trucks
I have a double pol 208 dgm100 and i conect whith contactor and i cant able to program please can you help
Tork digital timers and manuals appears on following link
DGM100 programming manual:
DGM100 is single channel timer, so timer operates all Loads at same time.
In other words, if you have 2 different contactors, the timer cannot set different schedules for each.
7-day programming
32 set points
Programming buttons:
1) When powering up the unit, model number 100P appears on screen.
LCD displays 12H which is an automatic (AM/PM) format.
Press ENTER to keep 12hour am pm -or- press HOUR to change to military time, and then press ENTER
2) Unit is in RUN mode and time displays.
3) Set current time:
Press DAY/Month key to select current Day.
Press HOUR key to set current hour (with AM/PM).
Press MIN key to set current minutes.
Press ENTER key to confirm.
Unit now stores present time. Seconds are set to zero.
4) Daylight savings time (DST) automatically adjusts for daylight savings time, if you choose this option.
In step 3 you set current time, but you did not set the Month and date.
YES DST: If you want DST then follow step 5 and enter Month and date.
NO DST: If you don't want DST, then skip Month and date, and move forward to step 6
5) Set month and date.
Press MODE until DATE displays
Press Month button to set current month
Press Date button to set current date
Press ENTER to confirm
6) Set programs
Press MODE key until SET displays
Display shows --:-- 01 which is program1
-Press DAY/MONTH key to set day(s) you want program1 to turn ON
Following are choices that display on screen:
MO to FR (MO, TU, WE, TH, FR)
SA and SU (SA, SU only)
MO to SA (MO, TU, WE, TH, FR, SA)
SU to SA (SU, MO, TU, WE, TH, FR, SA)
Individual days: SU, MO, TU, WE, TH, FR, SA, and D
for Special Day (usually a holiday).
-Press HOUR key to set hour {check AM/PM} you want program1 to turn ON.
-Press MIN key to set minutes you want program1 to turn ON.
-Press ON/OFF button to select ON, and then program1 will turn ON at your set schedule.
Press ENTER to confirm setting.
Display now shows --:-- 02 which is Program2
-Press DAY/MONTH key to set day(s) you want program2 to turn OFF
Choose same days you chose for Program1 ON so timer does not have conflicting programs.
-Press HOUR key to set hour {check AM/PM} you want program2 to turn OFF
-Press MIN key to set minutes you want program2 to turn OFF
-Press ON/OFF button to select OFF, and then program2 will turn OFF at your set schedule.
Continue setting up to 32 different programs.
When finished programming, press MODE button until RUN appears
Manual shows more programming options such as override, reviewing programs, setting special days.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
Aube timers are either dusk-to-dawn or 7-day
Utilitec 0192773 with 7-day and astro dusk to dawn
Utilitec 0141224
GE 15071 - 15086 in-wall timers: one has daylight savings time
Woods 59018 in-wall
Tork SS720 in wall:
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lost programming instructions, need help to reset or copy of programming manuel
Go to and you will see your model and then click on it for your wiring diagram
Oct 01, 2010 | TORK SS720A 7 Day In Wall Digital Timer
Hardware & Accessories Logo
50 people viewed this question
Top TORK Hardware & Accessories Experts
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
